Question about Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision is hot, to the touch, Is there concern?
My tv is getting hot to the touch. Is there a fire hazzard?
Rob Kent
    Habit-Forming:
    New Friend:
  • 21 Answers
I've owned a 42HDX99 since 2007, It's always been warm/hot. Still works/looks Awesome. Plasmas do generally run hotter than
LCD/LED's. Also have a 58" Samsung Plasma ( which I've had to repair ) and a 2009 Toshiba 1080P LCD ( still works great )
Posted on Jan 05, 2015
2 Related Answers
Anonymous
SOURCE: hitachi ultravision projection that is turning off
your Guru didnt even know this set is a plasma, look for the main filters on the power supply, the big ones to see if the tops of them are crowned these new sets are very particular when it comes to filtering.
Posted on Jun 08, 2010
gopakumarg43
  • 76403 Answers
SOURCE: Hitachi UltraVision Tv keeps turning off
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
google.com/+GopakumarGopalan
Posted on Nov 13, 2013
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
Hitachi ultravision director's series 55"
I don't know how to fix your issue but I have the same tv with a cracked glass front. I would be interested in buying your tv for parts to replace my glass front if you are unable to fix yours. Please let me know. Thanks, Dan
[email protected]
Jun 10, 2011 | Hitachi 55HDX99 55 in. Plasma HDTV
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
Hitachi 60" Ultravision TV - bad green tube that is leaking
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
Dec 09, 2009 | Hitachi Televison & Video
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
50" Hitachi Ultravision LCD
Good Day, imfamous44;
This is common for the HIT LCD projection. In most cases, I've seen, the manufacture will cover the cost of the "light engine", but you will have to call them and express your concern. 90% of the time they will cover this, be nice but firm.
Good Luck, big IRISH.
Jul 26, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Lights come on no picture
Check your manuel...the lamps need replacing, or the cool down fan does not work...the lamps can get so hot that it can cause a fire.
Jun 18, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision tv
tv comes on ,i hear but can not see
Dec 27, 2007 | Hitachi 50UX58B 50" Rear Projection...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 42HDS69 42 in. Plasma Television Logo
109 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
