Onkyo npt-1113p output voltage details
First of all, did you test the primary and secondary leads for resistance? They all should be from 2-30 ohms max. If they are, the transformer is fine. If they are open, you will need a service manual which may be on-line. If you need more assistance or would like to inquire about repairing your unit, please visit my website at audoserviceclinic.com. Thank you.
SOURCE: onkyo amplifier
Is power coming out of transformer at the right voltage. Also may have a power i.c. shorting to ground.Final anp i.c. may have a place to go to ground through a shorted capacitor.
GOOD LUCK
Big Red
SOURCE: The main transformer in my Sherwood amplifier is
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
SOURCE: Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
