SOURCE: main cooling fan switches on and off rapidly
hi there,
could i get the exact model # for your stove please?
SOURCE: F1 error code plus constantly beeps and Oven won't shut off
ERC is bad and must be replaced.
(The Clock).
SOURCE: Tenant's oven downstairs is very
i would have to say that there would be a problem with the ignitor and control regulator
SOURCE: Error code F64 on lower
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
SOURCE: Bottom Oven Does not work - F64 Code on Panel
If you look under the bottom door you will see a 3/4" tall slot the entire length of the door. This is where the cooling air blows out. In the middle of this slot is the air switch enclosed in a 5" long metal housing. You can see a thin metal paddle sticking out of each side of the housing. These paddles are spring loaded to angle slightly back. When the fan is on, the airflow will push the paddles forward. If they do not move forward, then you will get the error code. The simplest solution is to vacuum out all of the normally collecting dust that keeps the paddles from moving. To better access and clean the area, the black trim piece that forms the slot can be removed by unscrewing the two retaining screws. That can be more easily accomplished by first removing the lower door. This is very simple. With the door fully open, rotate the small metal clip on each hinge so it hooks over the protrusion on the other part of the hinge. Then lift up on the door (close it part way) and slide (pull) the door and hinges out of the hinge slots. There is no need to remove the entire unit from the wall.
