Question about Bell & Howell Video Cameras
How do you get a replacement clip?
I have a bell hoewll dv550 camera with the underwater housing unit the clip on the unit is broke. How can I get a new one?
Posted by amym64 on
5 Related Answers
Anonymous
  • 542 Answers
SOURCE: Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Posted on Aug 30, 2005
Anonymous
  • 33 Answers
SOURCE: underwater camera housing
I think I can.
I looked on Canon's site and no luck, so I searched and found a website that may be of some help.  It requires a free registration, but it seems legit.  It is called TheUserManualsite.com.
The User Manual Site - We found it so you don't have to!
It seems to be a website that serves as a repository for user manuals.  People upload the manuals they have and search for and put out requests for ones they are looking for.  Here is the link for the manual you are looking for.
http://www.theusermanualsite.com/manuals/mfg/canon/canon_wp_dc2_1163b001aa.html
It seems that no one has uploaded it yet, but you can request it if you register.
Sorry I couldn't find the manual, but I do think that should help if you can't find it another way.
Posted on Feb 04, 2008
tjjfitz
Tom Fitzsimmons
  • 8 Answers
SOURCE: Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Posted on Oct 21, 2008
Anonymous
  • 3006 Answers
SOURCE: SVP Acqua 1231 Underwater camera Need
This is not usually available as a spare part, but Silicon Valley Peripherals may be able to help if you send them a polite request. Their email address is:-
[email protected]
Good luck and please take a moment to rate my answer.
Posted on Sep 26, 2010
Testimonial: "Very rapid reply I await result of my E-mail. Seems hard to contact the seller Aitch and Dee or SVP. Many Thanks John"
Anonymous
SOURCE: Have a Bell and Howell DV550 video camera. Can
Buy an SD card
Posted on Dec 28, 2010
My intova sp1 won't turn on.why?
Please try to reset camera by inserting and pushing the end of a paper clip into the reset hole located on the camera back next to the Micro SD card port. Please also try to recharge the Li-ion battery by connecting he camera to a computer via the supplied USB cable. If either solutions don't work, then please contact Intova directly by either calling 808-837-0074 or email [email protected]
Is canon ixus 50 is waterproof?or can use underwater?
No, the IXUS 50 is not waterproof. You cannot use it underwater without an underwater housing.
No, the IXUS 50 is not waterproof, you cannot use it underwater without an underwater housing.
My Olympus Stylus Tough -6000 lost its underwater capability. it gets wet no matter how much i make sure the battery and USB gaskets/seal clean. can it still bi fixed? how?
I wish there was a way I could shout this to everyone so they would all know it at once....ALL SO-CALLED "WATERPROOF" POINT AND SHOOT CAMERAS WILL EVENTUALLY LEAK. THIS WILL USUALLY HAPPEN AFTER YOU HAVE TAKEN THOSE "ONCE IN A LIFETIME" PICTURES. The only real underwater cameras are in a special underwater housing.
2answers
I have this camera, and there is a theme for it that says "Underwater" is this camera able to go underwater? The lense looks as if.
No, it is not water proof camera so unable to shoot underwater without water proof casing that is another product. Camera must be packed in water proof casing to take pictures underwater.
Click Sony Support link to download optional accessories brochure rleated to DSC-T700 and check AKP-THA water proof casing for this model.
Thanks.
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Stylus Digital
Yes, the PT-016 underwater housing is designed for use with the Stylus Digital. It can be used at depths up to 141 ft.
2answers
Video Cameras Logo
Top Bell & Howell Video Cameras Experts
ray gallant
Tom Chichester
Tony Parsons
Tony Parsons
Are you a Bell & Howell Video Camera Expert? Answer questions, earn points and help others
