Could be several things causing the problem. You didn't say what size fuse you replaced. If you replaced the small fuse on the control board then you probably have a bad board.
If you replaced the fuse that provides 120/208 volts to the unit then either the compressor is bad, you may have a short in the power wiring or the fan motor is bad.
All three things can cause the fuse to blow.
Posted on Aug 27, 2014
Thank you for all your great advice, my husband is a refrigeration tech and not familiar with this unit we will try all these tips. I will ask him what fuse he changed
Posted on Sep 03, 2014
SOURCE: no heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Posted on Nov 14, 2007
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
SOURCE: I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Posted on May 05, 2010
Aug 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Jan 15, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Sep 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Jul 16, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Jul 15, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Nov 13, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
254 people viewed this question
