Question about Frigidaire FRA123CT1 Window-Mounted Compact Room Air Conditioner, 12,000 Cool BTU, 3.8 Pints/Hour Dehumidification, 640 Sq. Ft. Cool Area, 9.8 Energy Efficiency Ratio, AHAM Performance Certification, 3 Cool Fan Speeds, 3 Fan Fan Speed, Full Function Remote Cont
My Frigidaire turns its self up to 90 and none of the buttons work
Here is the thing i just got an air conditioner from Arron's, it was working fine for the first few hours. then it started turning its self up and now none of the buttons work, ecept when i hold down the down button it turns it into C instead of F i took it apart to see if there was a loose wire or something and there wasn't what can i do to try to fix it??
Posted by jaycas07 on
George Persico
    Sergeant:
  • 231 Answers
Return it under their warranty
Posted on Aug 27, 2014
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
My in the sleeve, wall air conditioner turns on fine and the fan seems to be working but no cold air comes out even after being on for an hour and lower temperture setting.
Hi, The unit leaked all of the refrigerant out...repairs may cost more then a new one...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Heating & Cooling
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
Fan on outdoor a/c unit not running
call in the technicians
compressor shutting down or power to the fan being interrupted causing the compressor to shut down
Jan 23, 2018 | Goodman CKL36AR36 Air Conditioner
Unit is icing up and not blowing cold air
Usually when this happens, the unit is low on freon. If you have an AC tech come out, make sure he does a leak check for you. Hope this helps... good luck!
Sep 02, 2009 | Samsung AW0505M Air Conditioner
Blowing warm air inside,blowing cool air outside
The odds are you are low on refrigerant charge and the compressor is going out in over load.
Aug 10, 2009 | Dometic Rooftop RV Air Conditioner
It turns off
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Jul 23, 2008 | Sharp AF-S100FX Comfort Touch Air...
Portable a/c water problems
either the area you are cooling is extremely humid or your a/c is freezing up, shutting off  and melting alot of ice before it comes back on.
Sep 02, 2007 | Maytag Portable Air Conditioner M6P09S2B
Frigidaire FRA123CT1 Window-Mounted Compact Room Air Conditioner, 12,000 Cool BTU, 3.8 Pints/Hour Dehumidification, 640 Sq. Ft. Cool Area, 9.8 Energy Efficiency Ratio, AHAM Performance Certification, 3 Cool Fan Speeds, 3 Fan Fan Speed, Full Function Remote Cont Logo
70 people viewed this question
Top Frigidaire Televison & Video Experts
Lawrence Oravetz
ray gallant
Are you a Frigidaire Televison and Video Expert? Answer questions, earn points and help others
