SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
SOURCE: my brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one.
code will remove.
wish you best of luck............
SOURCE: my bizhub 210 is coming up with an error mesage
its the code of ATDC sensor, that means your machine is having low deveolper, kindly change the developer to permanently get rid of this code. thanx
