The manual does not include instructions for how to enter the code for my Samsung TV into the remote. The manual does have a listing of the codes, and it does tell how to enter codes for components, but the remote has a separate TV section at the bottom, and the manual does not give any hint how to enter the code for Samsung TV
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
SOURCE: How to code TV into Yamaha RAV290 remote
You have to assign the tv code to one of the components such as AV1 or Audio 1. If you have to separate the audio from the video channels then you need to go to the yamaha website and look at the firmware update manual from august 2009. It tells exactly how to do this.
