Flat front tire
SOURCE: can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
SOURCE: what would cause white smoke from the front of my
It could be your valves. My friends mower was blowing a lot of smoke and I think some oil. I replaced the valves and it runs like a dream.
I can't remember the steps to remove and replace, sorry.
If you are mechanically inclined it shouldn't be that hard. The only problem I has was the new valves (keeper or whatever holds them in place) was different than the old one.
You could call a repair shop and get an estimate.
Good luck. Let me know if this any help.
roundo4
Testimonial: "Thanks for your opinion - now I have a few options to consider as I tackle to problem in the morning. Navytime"
SOURCE: need to know how to replace drive belt lawn tractor
Check out the video at the link that I am providing and see if it helps you with the drive belt replacement. Sure hope so and best wishes.
http://www.youtube.com/watch?v=YIRUAMSjGfg
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
