Computer says: Engine Communication Error and printer runs through calibration and warm up mode and then does nothing. Then the green power button comes on and the orange triangle button comes on and the large green button also comes on at the same time. Then the printer does nothing.
SOURCE: flashing red button with a triangle and ! in it . printer won't work
If only the attention light is flashing then follow the guide below -
The Attention (amber)
light is blinking.
Attention error. The top
cover is open.
Close the top cover.
printer is out of media.
Load media.
printer has a jam.
1. Clear the jam (see pages 164 through 168).
2. If the location of the jam is not apparent, check
the embedded Web server to find the jam
location.
If the jam was under the imaging drum, toggle
the registration sensor to check its movement
and replace the registration sensor if it does not
move freely.
If the jam was in the fuser area, toggle the fuser
exit sensor to check its movement and replace
the fuser exit sensor if it does not move freely.
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
SOURCE: Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
If the calibration is taking a long time that can be related to the ITB belt. If the printer doesn't think that the calibration is correct it will keep trying until it sees a correct image(color)
SOURCE: HP Laserjet Printer 2550n flashing orange light next to triangle
This is a link to HP for your Color Laserjet 2550n instruction manual. Look on pages 97 & 98.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00189910/c00189910.pdf
And for further troubleshooting, try this link.
http://h20499.www2.hp.com/gts/sparks/public/IPG_CLJ2550_All_toplevel_WhatDoYouNeedHelpWith_PUB_EN?lang=en&cc=US&product=Printer&series=na&subseries=na&prodTypeId=18972&prodSeriesId=388394
NOTE: Calibration might take 2 to 3 minutes. Do not turn the product off during calibration.
