Have you ever heard of RPM roll over? If the engine was allowed to reach it's max RPM under throttle the inertia would cause it to exceed its design max RPM, so it set below that to avoid flying rods and pistons. And yes it is governed.
I think the idle, in gear, should be about 750 rpm, definitely not 900. If you are looking at the tachometer, it isn't that accurate visually. a scanner should be connected to get an accurate reading. A little vibration at idle is not abnormal. But you might try adjusting the engine mounts to eliminate it.
