The washer had been working fine. Started a load and left it. Came back later to find it still full of water. Attempted to start a drain or spin cycle or anything - nothing happens. I spin the dial to various points, pull out the knob and nothing happens. Checked the plug and the fuse box - all good. What can I do?
SOURCE: Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
For a detailed Washing Machine illustration, click below.
Top Load Maytag Style
Top Load Whirlpool Style
Top Load GE Style
Front Load Maytag Style
Front Load Frigidaire/GE/Kenmore Style
Warning!
To avoid personal injury or even death, always disconnect your
appliance from its power source--that is, unplug it or break the
connection at the circuit breaker or fuse box--before you do any
troubleshooting or repair work on your appliance. Also, because some
components may have sharp edges, use caution while working on your
appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
SOURCE: Kenmore 80 Series will start to fill, then stops, will spin
your water level sensing switch is defective.
it sounds like a bad timer there....! if after you selected a different load it drained......!
if it didnt drain at all on any mode I would say a bad lid swtich.
SOURCE: washer,15 years old, has a load in it,full of
off bal. on lid switch is displaced probley need to call a tech.
