Hi Ginette
The camcorder has a built in Dew sensor that monitors the condensation in the area of the camcorder while it is in use. Normally after leaving the area where the condensation is and the camera sitting for a while it should reset itself, if it doesn't then the dew sensor needs to be replaced. On the model that is shown in the picture it is on the motor bracket assembly. I could be more specific if i had an exact model number.
I hope this helps.
Eject the tape. Leave the tape carriage open. Power the unit off and tent it with a light linen cloth for about 20 minutes in a warm but obviously low humidity area. Emergency/ short time approach: Clean hair blow-dryer. Set for warm/low heat. Turn on and "wave" the warm air into the tape mechanism section about 18 to 12 inches away from the camera's open gate/door. Bake for 3-5 minutes..
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape. Good Luck, Luwangula
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
I have the same problem with my PV-DV103. Panasonic wants more to TRY and fix it than the camera cost new. MY advise can the camera and buy one without the DEW option.
Thats what I am searching for presently . If the manufacturer says the camera has a dew indicator in the circuit - buy elseware.
