Question about GE 21 cu ft Top-Freezer Refrigerator White ENERSTAR GTH21GCEWW
Plastic door shelves fall out
Door shelves "snap" in for easy cleaning but have fallen out 4 times. Do not put heavy liquids in because learned hard way. Husband wants to screw them in, but I do not think plastic will hold. We are considering epoxy, but hate to make it permanent. Called GE, they sent 2 replacement shelves the same size as the other ones. Really needs a pin to hold in. Any suggestions? Thanks
Richard Warren
    Genius:
  • GE Master
  • 2,548 Answers
Try small cable ties if they sit on pegs sticking out you can then cut the ties for removal.
Posted on Aug 27, 2014
1 Related Answer
Anonymous
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
HOW DO YOU GET THE DOOR OFF?
There is usually a plastic part covering the top hinge. It will pull or snap off, rarely there might be a small screw.
Remove that plastic covering, and then unbolt the part of the hinge assembly attached to the body of the freezer.. DO THIS WHILE THE DOOR IS CLOSED! That is so the magnetic seal around the door will tend to hold it in place. Lean against it as you remove the hinge part so the door does not fall away and land on you, or even worse: break the door!
Slowly lift the door out of the bottom hinge, and carefully set it somewhere safe.
Be VERY CAREFUL when you set the door down. If you set it upright, against a wall or something, be aware that there is a pin sticking out the bottom of that door hinge, and it will likely simply ruin any flooring you set it on - and I speak that as a "voice of experience"!
Have fun!
Mar 17, 2015 | Freezers
Freezer Will not freeze in some areas
Check the door gasket near those shelves.
Make sure the condenser fins or tubes have adequate air flow for cooling (it looks a bit like a small but fat car radiator). In most freezers, this will be in the bottom in the back. You may have to remove a vented cover to check this. Usually there is a fan blowing air through the condenser. Carefully vacuum out any dirt in the condenser (the fins are delicate and bend easily), and verify that the fan runs smoothly when the compressor is running.
Put a thermometer in the freezer right by the cold air inlet to verify that the refrigerant is doing its job. It should read 0 degrees F. or below (-18 degrees C). If it doesn't get down that far, the compressor needs to be recharged or replaced.
If the door has been hit hard (somebody falling and slamming into it) the door insulation may be damaged there. Check to see if the outside of the door feels cold there compared to the rest of the door. If it does, the door needs to be repaired or replaced.
Aug 03, 2017 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
I bought a used Kenmore upright freezer, it's been on for over 24 hrs, and it freezeswell, BUT won't turn off. Runs alllll the time. Any suggestions??
Did you transport it STANDING or LYING down?
If Standing 4 possibilities:
1. The thermostat is hosed (replace)I had one like this and just put it on a $6.00 24hr time to turn on for 1hr every 5 hrs. (New Thermostat was $40.00)
2. The heat exchange fins on the back are dirty(clean with broom and air/vacuum cleaner)
3. The Door seals arent sealing and cold air is falling out the bottom, pulling hot air in the top (rehang door or replace seal) Note: a piece of paper 2" by 8" should be hard to pull out all the way around when closed. Like a cash register reciept. Cleaning with armor-All and then thinly coating with Vaseline may help
4. The Freon is shot and needs a recharge. (Costs $40-100.00)
If transported Lying down, there is now air in the lines and it needs to stand OFF for 24hrs. You may have hosed the pump with the air/freon mix, but let it stand so the air can surface and retry
Mar 26, 2009 | Freezers
GE 21 cu ft Top-Freezer Refrigerator White ENERSTAR GTH21GCEWW Logo
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Dan Webster
Dan Webster
Are you a GE Freezer Expert? Answer questions, earn points and help others
