Question about Denon Audio Players & Recorders
Denon AVR-1513 Hello, I have a Denon AVR-1513 It starts up but when it goes to Cbl/Sat it shuts itself off and goes into protection mode i can't get further then Cbl/sat I even did the microprocessor reset and nothing any suggestions?
Posted by Joseph Rod on
Dennis McCollum
  • 137 Answers
Disconnect speakers then try again if still shutting down you will have bad outputs.
Posted on Feb 19, 2015
5 Related Answers
Anonymous
  • 682 Answers
SOURCE: I have a Harmon Kardon
please check all speaker cables for short circuit in receiver side or in the speaker side itself.
Posted on Jun 25, 2008
SOURCE: DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Posted on Aug 22, 2008
Anonymous
SOURCE: Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
i have the same problem . denon had changed knob and circuits ?! one day later ... same issue !
i have 5.1 evo tangent 4-8ohms and 2 technics 8ohmsand i use frquently A+B configuration
Posted on Nov 08, 2008
mattvierra
Matt Vierra
  • 75 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
ABRsvcs
  • 4234 Answers
SOURCE: HK AVR-247 protect mode
This is an indication of an internal problem. Typically this is shorted output transistors. Expect a parts cost in the $25-$40 range for this repair.
Dan
Posted on Apr 06, 2010
I need help on how to set up my receiver AVR 1513
The owners manual can be found at many sites on the internet if you google for Denon AVR 1513. One site is amazon.com.
http://s3.amazonaws.com/szmanuals/d357e31200b1de2a76b2e5619ef9cdd8
Jul 07, 2014 | Denon AVR-1513 3D A/V Receiver - 5.1...
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Avr 1513 no signal to subwoofer
Check its speaker connections. Check the speaker using a dry cell. If it is found OK, check the sound settings. If you wish to get more details, check this link.
Mar 22, 2013 | Denon AVR-1513
Denon avr-1513 shutting off and blinking red light
Sounds like you could have a bad speaker connection. Try disconnecting the speakers and see if it stays on. If so, connect one at at a time until it goes off to determine which one.
Jan 20, 2013 | Denon 5.1 Channel Receiver 1080p AVR-1513
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
I have a Denon AVR - 391 receiver and was wondering the best way to connect my CD player to as there is no provision for CD player
Sure it does:
http://www.retrevo.com/support/Denon-AVR-391-Receivers-manual/id/23705bh449/t/2/
Analog RCA cables go to anything available: DVD; SAT/CBL; DOCK
and/or
Digital audio goes to whatever is available: COAXIAL (SAT/CBL) or OPTICAL(TV)
Jan 09, 2011 | Denon AVR-787
Denon AVR-1604 too large front speakers blew the avr
Try disconnecting the speakers at the receiver. turn it on radio or any other source and turn up the volume. If the receiver still shuts of, there is an internal capacitor issue and needs serviced. More than likely though, it's a speaker problem. If the speakers were underpowered and at max volume, chances are the damage was to a voice coil in one of the speakers. If the receiver continues to stay on without being connected it's ok. check your speaker wires as well. Frequently loose braids on wires touch each other and create very little resistance until turned up, more volume, more resistance. Then the receiver puts itself into protection mode so no damage will occur. If you need further help, post a comment and I can help you troubleshoot further.
Aug 17, 2009 | Denon AVR-1604 Receiver
My denon avr-a10se stop working. When I start, aftr thr quick intiation the amp shuts itself and the red power light start to blinvk quickly - please help
This unit is in protect mode. This means that a problem was detected in the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common failure parts are the output transistors. These usually run between $5-$15 each. Add in the local labor rate for the total repair cost.
Dan
May 20, 2008 | Denon Audio Players & Recorders
267 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
