Question about D-Link Computers & Internet
Can I hook a mifi to a dlink wbr-2310 router
The only internet i can get where I live is wireless through a mifi device. I bought a baby monitor with the option to view it on my iphone but the little gateway it came with is wired and I have no place to plug it in. Was hoping I could somehow set up my router on my mifi so I could plug it in to the system.
Anonymous232
    Genius:
  • D-Link Master
  • 1,552 Answers
The WBR-2310 router has FOUR 'LAN' ports.
Plug the baby-monitor into one of those ports.
Posted on Feb 05, 2015
4 Related Answers
Anonymous
  • 1383 Answers
SOURCE: dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
Posted on Jul 23, 2009
govinda123
Prashant M
  • 2277 Answers
SOURCE: I have a Gateway nv52 laptop and a dlink wbr 2310
So that means you are able to connect to the network with the ethernet cable only.
Did yopu try to connect to the wireless network ?
And if yes then what was the error message ?
Click Here for more info about wireless connection. Pl. go through the web site you will get the answer !
Posted on Oct 10, 2009
Testimonial: "Thanks"
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: wbr-2310 wireless stops resonding randomly.
unplug for 10 seconds, plug back in. These units to tend to get a stat build up charge
Posted on Nov 08, 2009
Anonymous
  • 10 Answers
SOURCE: wbr-2310 dlink router wired connection issue
connect your computer to the router by an ethernet cable. Open Internet explorer or FIREFOX. Type the roiuter's default IP-address (if not known: its either 192.168.0.1 or 192.168.1.1 or 192.168.0.0 or 192.168.1.0... keep trying until you're answered and asked for the password to enter the router (either attached on the router, in the manual or try: user: admin password: admin or password: password. Whgen you're in you'll find many checkboxes you could fill oput or notr; Easyway: give your net a name (SSID), then choose the network access security (set it to wpa-psk), choose a password and enable DHCP (then the router does the rest). Disconnect, look if the computer sjhows reception of your netwoirk by displaying its name. then connect. You will be asked for the password you chose. Done.
Posted on Jul 26, 2010
Have dlink router 1310 when switched over to jumpstart no longer usable
There are multiple versions of both of your routers, you can click on your version and try there tech info from there. If you have no luck, just post the right versions here and I'll see what I can do for you.
There are multiple revisions of the WBR-1310, each with revision specific drivers, firmware, installation guides, and other resources.
There are multiple revisions of the WBR-2310, each with revision specific drivers, firmware, installation guides, and other resources.
Go to there support page and click on your model.
http://www.dlink.com/products/default.aspx?pid=WBR-2310&tab=3
Dec 22, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 dlink router wired connection issue
Jun 04, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Need to re-set my ssid network name to re-secure my wireless network
Some support information for your router can be found at dlink site:
http://www.dlink.com/support/
type wbr and select 2310,
Product info at this site contains manual:
http://www.dlink.com/products/?pid=WBR-2310
Choose Support Resources tab and then select whether or not you have RevB (it will guide you how you can tell).
You can then download the Product Manual. In the non-RevB manual, what to do with SSID is described on p25, showing where in the set-up interface to enter it. The RevB manual will likely be similar, depending on your exact model.
If you don't know how to access the device's settings, send back a comment and I will assist you further.
Sep 13, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Lost the cd to my d-link 2310
Go to this link:
http://www.dlink.com/products/?pid=470
Proceed to download required software.
Remember to give a good rating for a good comment! Thank you for using fixya.
Aug 04, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Dlink wbr-2310 router no wireless working
http://192.168.0.1
http://192.168.2.1
Jul 23, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I need to download the installation cd
You do not need to install any software in order for a router to opperate.
Jul 22, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Unable to access DLink WBR 2310 Configuration page
At the back of the router is a tiny pinhole. Using a pen try to press it for 15 secs and try to access the page using the 192.168.0.1
Jan 02, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
90 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
