Question about LG LMX25981ST Stainless Steel Bottom Freezer French Door Refrigerator
How to repair LED lamp in a lg refrigerator, model lmx25981
One of the LED lights is blinking. How do I open the cover and replace the bad LED
1 Related Answer
Richard Lew
  • 489 Answers
SOURCE: Refrigerator light not working before fail light
If you have checked the light switch and found it to be working normally, then you will need to replace the control board because the light bulb is controlled by the relay switch. It is not directly connected to the light switch. Good luck
Posted on Jun 19, 2011
Will LED power supply fix my black screen on TV?
Chances are you have bad lamps in the panel...you will need to take the front cover off and get under the panel and test them and see if some are bad, if they are replace the strip...good luck as its not all that easy to get the panel off and back on without damaging it, use extreme care handling it or once you get the lamps working the panel can be damaged and then it has to be recycled as it can't be fixed
Mar 19, 2018 | LG Televison & Video
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Water dispenser stuck on lmx25981 lg fridge
open the front of dispenser check spring might be broker or came apart.
Jun 26, 2014 | LG LRSC-26922 Side by Side Refrigerator
How to fix light not going off in refrigerator
Replace the main pc board. Was part # 6871JK1011C, with a 5 amp light relay, now should use the new board, part # 6871JK10011F, with a 16 amp light relay, which will prevent relay contacts from welding themselves together. Should also replace the lamp socket harness with part # 6621JK2003B which now has a thermostat on it to prevent lamp from overheating and melting lamp cover. Contact a locally authorized LG servicer or LG directly to have the servicer replace this for free, even though technically it is out of warranty, LG will cover the repair. (servicer may need an authorization code to get credit from LG)
Mar 16, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Mitsubishi WD 52525 lamp replaced, no picture, red light
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Jan 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replaced Lamp & yellow light indicator blinking. Still no picture
Good Day;
1. Check for an open AC fuse F9D00, if open check for a short on the 340v line to the lamp ballast between pin 1 an 5 at connector PL on the Power PCB, if shorted replace PWB-POWER LAMP (Ballast) part # 939P978010 and F9D00 part # 283D131040 2. Check for open AC fuse F9D00 part # 283D131040, if open check for proper seating of connector K1 on the Power PCB
Dead unit wd52525 mits
NO POWER
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A 1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Oct 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light on
Good Day;
Most likely you have bad caps on the TV's power supply. The following will guide you in the correct direction to properly repair your TV. Good Luck, big IRISH:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) .
Sep 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
LG LMX25981ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
78 people viewed this question
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
