SOURCE: Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
SOURCE: Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
SOURCE: viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
SOURCE: Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
SOURCE: Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
