Question about Konica Minolta Office Equipment & Supplies
Minolta Di1610 error message - change t/c??? incorrect t/c type??? What to do???
Minolta Dialta Di1610
Robert Groffel
    New Friend:
  • 62 Answers
Google it just as you typed it out the manufactures web page will explain better than we can
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_c7b5aba9012a13b2
Posted on Aug 26, 2014
3 Related Answers
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: Minolta di1610 error message
What error message? Does itsay toner cartragie need replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: I have di1610 wont at all error ligth are flashing
Description
Machine may cycle ON/OFF repeatedly (keeps rebooting), will not power ON (no boot-up), no message on the operation panel, LCD displays extraneous
characters and/or error code C14A3 (C-14A3).
Solution
CAUSE: The PCL board draws too much current, causing PWB-P to fail. There is no problem with GDI versions of the machine; only machines with PCL
boards are affected.
SOLUTION: The PCL board has been modified to limit current draw. If the symptoms described above occur, replace both the PCL and PWB-P boards.
Note : The new-style PCL board can be identified by a yellow sticker. Machines that had the new-style board installed during production have a yellow
sticker near the serial number plate.
may want a service technician to check the PCL boards as above
Posted on Aug 08, 2009
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: how to fix the C0210 Error on minolta dialta di1610?
The C0210 error code deals with the Primary charge unit... It is part of the drum unit. It may not be installed correctly or it is not in all the way..... Good Luck
Posted on Jun 06, 2012
Testimonial: "Thank you so much....! now it's working i just check the drum caridge and install properly"
How to reset the C0500 code on a Di1610 machine
power off the machine, then hold down the stop button and power on. if the code comes back DO NOT RESET the Fuser (HOT PART BACK OF MACHINE) is bad it can catch on fire REPLACE IT.
Jul 02, 2014 | Konica Minolta DiALTA Di200 Copier
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Service Manual
Here you go.. took some time but I found it.
http://www.manualslib.com/manual/90085/Konica-Minolta-Di1610.html#manual
Next time try here.. http://www.manualslib.com/ for all kinds of manuals.
Hope this works.
Nov 23, 2012 | Office Equipment & Supplies
How to fix the C0210 Error on minolta dialta di1610?
Jun 06, 2012 | Office Equipment & Supplies
Hello i have dialta di1610 printer. but i don't have driver to install.. i seach in google but could not find the driver. can you please let me know the site from where i can download the driver
Here is a link to the Konica Minolta website where I download all the drivers for my customers.
Just pick Black & White under Product Group, then scroll down the list of models under Product until you see the Di1610, then select drivers under File Type and then your operating system. It will then give you how many files are available at the lower right corner of the screen. Click show files and there they will be. All free of charge.
Good Luck and Thank You for using FGixya.
Wheatland Services
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht
Feb 08, 2011 | Konica Minolta DiALTA Di1610p Printer
Description
Solution
Aug 04, 2009 | Minolta Office Equipment & Supplies
Apr 04, 2009 | Konica Minolta Di1610 Copier
How do I input ip address in Minolta DI1610
press the Utility/Counter -> Network Settings -> IP address
Feb 09, 2009 | Konica Minolta Di1610 Copier
Konica Minolta Di1610 can't print
hello
is it conect via net or parall port?
have you try to detect the printer by its ip ?
(ping)
pini
Feb 14, 2008 | Konica Minolta Di1610 Copier
168 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
