Question about TCL L32D20
How do I connect my TCL Smart TV to my Wifi network?
How can I connect my TCL Smart TV to my wifi network? It can find my network and when I try to connect it times out. It also recognizes the right password and tells me when it's incorrect. All my other devices are connected fine, so I know it's not my internet connection.
Rami Elayan
    New Friend:
  • 7 Answers
Try restart your router, it might help, check the bandwidth of your router.
Posted on Jan 26, 2019
m afzal
    New Friend:
  • 8 Answers
Go to network setting.serch your wifi network, give password and then conect
Posted on Sep 02, 2014
  • Samantha Nov 13, 2016
    How do you add the TV's MAC address to the list of permitted devices?
Terry Hair
  • TCL Master
  • 4,134 Answers
Check your router to see if the MAC Filtering feature is in use. If it is then you will need to add the TV's MAC address to the list of permitted devices before the connection will complete.
Posted on Aug 26, 2014
I am hving trouble connecting netflix on my tv. Hoe can I tell if my wifi extender DC is working? Gene
Can you please elaborate in details, what all you are trying or how you are planning to connect your TV. or Is your wifi and wifi router is working properly and wifi is configured properly on your smart TV.
Aug 13, 2018 | Computers & Internet
Can you please help me to connect my tv to the internet?
If your tv is indeed a smart tv, you only need (through the appropriate tv menu selection) to scan for wifi networks, find yours, select 'connect' and then give the wifi password (see the tv manual in order to find where is that menu). If the list of the networks does not include yours then maybe the tv is out of range and you may need a wifi extender.
If your tv is not a smart tv then you should get a 'smart tv box' (about 50 euro cost)
Nov 15, 2017 | The Computers & Internet
How do I get my LG smart tv to connect to Wifi
change your WiFi security setings in your router from WPA/WPA2 to WEP.
Go back to the Smart TV and reconnect to your network with your selected security key.
It may be less secure but it may be the only setting your tv will recognize.
Sep 11, 2017 | LG Computers & Internet
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Sep 20, 2016 | Samsung Televison & Video
Smart to will not connect to wifi ?
If you wish to get some details; check the site linked here. Pull up older posts. Check for article about Smart tv Network connections
http://electro-medical.blogspot.com/
Jun 26, 2016 | Televison & Video
How do I connect to wifi?
Setup menu - WiFi - LAN - Network if this does not work try going to web browser to get an error message.
Samsung 3D LED Smart TV Setup menu WiFi LAN Network
Mar 14, 2016 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
How can i get my smart tv to connect to the internet it is already connected to my wifi but when i click to connect to the internet it comes up no internet connection?
Check to see if your laptop or phone gets online via wifi to see if wifi is on the net, and try rebooting your wireless router by unplugging, then plugging in. (do not press "reset" button on router)
Feb 26, 2015 | Televison & Video
How do I connect to the smart tv
I assume you want to connect your smart TV to your network (e.g. to get Internet access for NetFlix).
Depending upon the precise model, it will support WiFi or wired Ethernet (or both). If your TV supports a wired connection, that will provide the best performance. All you need is a spare port on your router/switch and a straight-through network cable.
If your TV supports WiFi, you'll need to get into the its setup to enter the settings matching your home network - that is, you must choose the SSID (essentially, your WiFi network name; so your TV connects to your network and not your neighbor's) and wireless security information.
Feb 13, 2015 | Smart Computers & Internet
TCL L32D20 Logo
7,782 people viewed this question
Top TCL Televison & Video Experts
Lawrence Oravetz
john h
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
