Bose SoundDock® (Black) Docking Station for Apple iPod Logo
A
Anonymous Posted on Aug 26, 2014
Bose sounddock replacement remote will not work?
Lost the original remote for my Docking Station.I purchased a new one, how do I make it work?
4 Related Answers
Anonymous
  • 20 Answers
  • Posted on Dec 11, 2008
SOURCE: Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Anonymous
  • 71 Answers
  • Posted on Jun 01, 2009
SOURCE: does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
Anonymous
  • Posted on Dec 03, 2009
SOURCE: docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Anonymous
  • 69 Answers
  • Posted on Apr 19, 2010
SOURCE: My Bose Sounddock stopped playing. I believe
mostly the flatcable from the dockingplug to the ampifier has a bad connection ,try to connect it again or resolder the contacts
I have a Bose cradle white and my son lost the remote control, I need to get one asap.
You can purchase replacement remotes from Bose on the product page under the accessories panel: http://www.bose.com/controller?url=/shop_online/digital_music_systems/sounddock_systems/index.jsp
3helpful
2answers
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Bose sounddock not giving any sound. Ipod working fine through earplugs. Unhooked soundock for travel, now no sound. Tried all the resets, etc. Also, new battery in remote and it doesn't respond either????
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
20helpful
6answers
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
23helpful
5answers
Bose Docking Station incompatibility with IPOD Touch
You need to reset your ipod. You can go online to find out how to do this. I had to do it with mine and then it worked perfectly.
8helpful
3answers
New ipod nano not compatable with bose docking
This is true. The new iPod nano is not compatible with the original SoundDock. This only means that it won't charge the iPod's power. Audio should be okay. This is an Apple issue. They changed the way almost all of their iPods charge (except the iPod classic). Bose can upgrade the SoundDock for their normal repair fee of $99. This would also you a new 1 year warranty.
Bose docking station problem. Remote will not work on either my ipod touch or I Phone. The volume buttons work on the remote but the skip and pause/play buttons do not. The Bose is brand new and straight...
If it is brand new. It is under warranty. Go back to the store where it was purchased and tell them the problem. They should replace it with another new one. Have them show you how to use it on all of the functions on your Bose Docking Station. Make sure you tell them about the ipod Touch and the iPhone.
8helpful
2answers
Does the new bose dock station charge the new ipod touch (32g)?
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
