Question about Sony Ericsson K300i Cellular Phone
K300I opening the streaming settings
Posted by chengki on
michael ramos
    New Friend:
  • 86 Answers
What is your network? (Service provider)
Posted on Feb 01, 2008
Anonymous
Hi my phone profile select port handsfree
he is on work in normal profile
i select normal profile but he is on use port handsfree profile
i am very upset plz help me and give me a code my id is [email protected]
regard ,thank's
Posted on May 06, 2008
Anonymous
  • 46 Answers
Be more specific
Posted on Nov 09, 2007
With screen part of wording is cut off but otherwise screen is displaying. How do I set screen setting correctly
Change settings for streaming media in Windows Media ...
windows.microsoft.com/.../change-settings-for-strea...
Microsoft WindowsLearn about media streaming settings in Windows Media Player, including how to block or allow streaming to ... You can also decide which devices will have access to your media. Picture of the media streaming options control panel Media ...
Open the Windows Media Player Settings troubleshooter
windows.microsoft.com/.../open-the-windows-media...
Microsoft Windows... Online Troubleshooting Service, your computer should be connected to the Internet. ... and then clicking Control Panel. ... Click View all, and then click Windows Media Player Settings. For more information about playing audio or video files in WindowsMedia Player, see Play an ... United States of America Change region.
windows media player visualization resolution settings - Microsof
Jan 12, 2016 | Televison & Video
We are ttying to "stream" and cannot connect to netflix
Hello.
To stream on Netflix your Netflix account has to be set up to stream.
For Netlix user's your account would be either streaming OR playing DVDs, not both.
If your Netflix is set up to stream, you may need to download Microsoft Silverlight which is free and availble from Microsoft.
Be sure to download the latest version of Silverlight.
You will also need to open Netflix.com and create an account on your computer.
Close netflix and reopen after creating account then login.
Then check your account for streaming or DVD playing.
Depending on why kind of TV you have to watch a movie you will need to connect to the TV with an HDMI cable.
Apr 17, 2014 | iPhone Apps
1. My 2008 MacBook Pro rejects most cd's and dvd's, has a Intel 2.5 GHz Intel core 2 processor. 2. When I downloading or streaming movies they keep re-buffering
Solving Problems with Streaming Services
If the Server Does Not Start Up or Quits Unexpectedly:
  • Check the error log.
  • Make sure the QuickTimeStreamingServer file is in the /usr/sbin/ folder.
    You must be logged in to the server computer as Administrator (root) to see the QuickTimeStreamingServer file in the Workspace Manager.
  • Use the Mac OS X Server Setup Assistant to reconfigure the Ethernet ports.
If Media Files Do Not Stream Properly:
  • Make sure the movie file is supported by the QuickTime Streaming Server. Check the list of compatible file formats.
  • Try streaming a sample movie to see if the server can stream it. You can download a sample prehinted movie from the Apple Software Updates Web site: http://www.apple.com/swupdates
    If the server streams the sample movie, the problem you're having may be with the way your movie file is prepared. Recreate the movie.
    If the sample movie doesn't stream, the problem you're having may be with the server computer or the network.
  • Try hinting the movie again with the Optimize Hints For Server option selected.
  • Check streaming server activity and if necessary, reduce the number of connections or throughput.
  • If the problem occurs on a Mac OS client computer, open the TCP/IP control panel on the client computer and make sure MacIP is not selected.
  • If the problem occurs on a client computer, make sure the user has the appropriate settings in the Streaming Proxy and Streaming Transport panels of the QuickTime Settings control panel. The administrator for the client computer's network should be able to provide the correct settings.
  • If the problem occurs for media streamed using PlaylistBroadcaster, try hinting the movies again with the RTP Payload Encoding set to QuickTime and Smooth Data Rate enabled.
  • If you are reflecting more than one live stream, make sure each stream uses a separate UDP port. Otherwise client computers will show a message with error 500. You set up ports in the relay configuration file.
If Streaming Service is Slow:
  • If you are streaming QuickTime movies, make the movies self-contained using your authoring application, and make sure hinting is optimized for streaming services.
  • Reduce the maximum number of connections or the throughput.
  • Turn off other services.
  • Place media files on other hard disks to improve server performance.
    Because QuickTime Streaming Server can use only one media folder, you need to create links from the folder you have selected in QuickTime Streaming Admin to the media files on other hard disks. To do so:
    In the Workspace Manager, press the Control key and drag the folders that contain the media from the other disks to the folder you have selected as the media folder.
Aug 04, 2011 | Computers & Internet
I'm not able to play Youtube videos on my lg GS500v cookie plus. please help.
Open top menu and select "Connectivity", which is present in settings section. In that, open "Streaming settings". Touch on button below the Internet profile. Select the internet profile that you are currently using for browsing or any streaming profile provided by your ISP.(E.g., BSNL provides separate profile called bsnlstream for streaming and bsnlnet for browsing, whereas, providers such as Tata Docomo provide TATA.DOCOMO.INTERNET as APN for both browsing and streaming). Hence, select appropriate profile according to your ISP. Now you will be able to play youtube videos
Feb 05, 2011 | LG Cell Phones
How to set-up streaming settings on my LG KM555E,,? Is it compatible in streaming videos??? anyone among you guys can help me?? pls. post answer here or send me email @ [email protected] thanks guys,...
Yes the device is compatible in streaming videos, your streaming setting should be on one of the following channels (depend on carrier):
Stream 3gp H264 .level10
Stream 3gp H264 .level10b
Stream 3gp H264 .level11
Stream 3gp H264 .level12
Stream 3gp H264 .level13
Stream 3GPP AAC LC
Stream 3GPP H.263
Stream 3GPP AMR NB
Stream 3GPP AMR WB
Stream MP4 H.264 Level 11
Stream MP4 H.264 Level 13
Stream MP4 AAC LC
Dec 08, 2010 | LG KM555 Cell Phone
My freetalk buddy webcam doesn't stream. can't find the software
Open Windows Live Messenger
Click ( > ) Show menu > Tools > Audio and video setup - set mic as default - test > Next - set webcam as default - adjust settings > Finish
Sep 22, 2009 | Microsoft LifeCam VX-3000 Web Camera
HI.I was watchinglive streaming but there is a eror sudenly.this eror:rtsp://78.129.143.64/broadcast/pull/81.31.32.47:2030/broadcast/pull/81.19.7.50:3051/stv3.rmvb Can you help me...
Streaming audio/video quality can be affected by connection rate and Internet congestion. Many types of interruptions between your computer, your player, your computer's OS, your local network, your ISP and a streaming server can exist and cause trouble....
When you listen to the live audio/video stream, the sound or video skips, cuts out or buffers if the player doesn't have enough network bandwidth, it will buffer. Try increasing your player's buffering setting.Also:
  • Make sure you are choosing the appropriate bandwidth version of a media stream based on your Internet connection.
  • Make sure you are choosing the appropriate bandwidth settings in an Internet media player or streaming audio/video recorder.
  • Make sure NOT to download applications or files while watching/listening to media streams. Your Internet connection is shared between all open applications including your web-browser, your download manager and your streaming player. Closing applications that use your Internet connection simultaneously with your streaming player may reduce buffering.
  • Close other unnecessary applications that may be open on your computer. Reboot your computer. If you have lots of other programs open, they may be using too much processor time and/or RAM for the player to work properly.
  • Make sure your Internet connection is fast enough to reliably listen to streaming audio and/or watch streaming video online. High speed Internet connection is recommended.
  • Make sure your computer is fast enough. If your computer is old, it might be too slow to play an audio/video stream regardless of what else it's doing.
  • Update your media players and streaming audio/video recorders regularly.
Internet congestion can slow down the delivery of the stream, make it difficult for you to connect or cause buffering. Often the interruption is temporary. Please try to connect a few times at different times of the day, if possible. If you repeatedly have problems connecting, please notify your ISP - there are often quick fixes they can make when they learn about your issue.
Try the above steps you will find a solution to your problem....100% it will work.....
Sep 18, 2008 | Computers & Internet
Sony Ericsson K300i Cellular Phone Logo
240 people viewed this question
Top Sony Ericsson Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
