Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
How to activate SAP? - DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Can't get it out of SAP mode. tried two different remotes. TV doesn't respond.
1. If you're watching TV via a Cable or Satellite box , then the SAP (Secondary Audio Programming) is activated in the box, not the TV. Check with your TV service provider how to activate/deactivate SAP in their box.
2. Only if you're using the TV's own built-in tuner to watch TV (you're changing channels by using the Panasonic remote for CH up/down), then press the SAP button on the Panasonic TV remote to cycle through the SAP options.
Mar 15, 2016 | Panasonic Viera TH-50PX80U Plasma TV
No Volume from cable input
The sound is probably set to the SAP channel (language) and the SAP channel is not active on the program you are watching. Just push the SAP button on the remote. The button might be labelled SAP or LANG. This will return you to the main sound channel which is always active.
Apr 18, 2014 | RCA F32645 32" TV
Iterra elite II printer showing fatal error 131 code error
Error Code: -131, ErrorMessage: Connection to license server failed; if license server address is invalid, correct it; if TAO NT naming service stopped, activate it and restart License Manager
I was sure that all SAP B1, and MS SQL services are up, and running on the server side so I knew this is an issue related to the client side.
The solution was checking the file "b1-local-machine" which is located it under "C:\program files\SAP\SAP Business One DI API\Conf"
The value of the server ip was "localhost", and it should be the ip of my production server instead.
Hope that was helpful.
for more hrlp visit CBR Tech Solutions
Feb 04, 2014 | Elite Office Equipment & Supplies
Hello friends...i have a 15 lcd of alba company..model no alcd15tv2 ro3sx2...i m having problem with my tv sound as when i connects to tv through rf in sound dosent come...and when i join a dvd or any...
You have something in the set's menu set wrong--if sound ok with a DVD set is ok---look in menu for something like SAP= most sets have Mono-Stereo-Sap settings.
Sap is secondary audio program which is for a second language to be broadcast (French, Spanish etc.) and if not active there will be no sound on selected channels.
I suspect a careful look will show SAP is engaged and some remotes have a button (MTS etc that will unwittingly get pressed).
Good luck and hope this helped.
Apr 18, 2012 | Televison & Video
Hi I pressed the wrong button turning the TV on, now I have no sound and can't get it back. please help.
SAP (Second Audio Program) may be turned on. This used to be a widespread RCA problem maybe caused by incorrect conversion of analog signals for viewing as phony HD images. Costly class action lawsuits addressed the problem in USA. Most of the specific equipment causing the problem used by broadcast/production/satellite industries was either adjusted correctly or replaced. If the problem re-occurs, it may caused by specific TV channels or programs that you watch. Codes inserted in the signal are incorrect and confusing the RCA TV Guide and audio processing circuits. The error causes SAP to be incorrectly selected as default for all channels.
Remedies:
Change audio settings in customer adjust menu to Stereo from SAP. Sometimes the On screen TV Guide set-up must be cleared of location, etc., and set-up again.
Sometimes it is difficult to set correctly. Unplug TV for 12-24 hours and TV may reset to default stereo setting instead of SAP.
This was an active Class Action legal issue 10-15 years ago in the USA.
easyab
Feb 23, 2011 | RCA Televison & Video
I have no volume on certain channels
The most common problem with no volume only on certain channels is the TV is programmed for 2nd Audio, also referred to as SAP which is a feature activated to transmit a second language such as Spanish. If you push your menu button on your remote control you can toggle over to Audio Menu. Then find the feature that allows you to adjust the sound for Mono, Stereo or 2nd Audio (SAP). Adjust the menu to highlight Stereo and that should cure your problem.
Hope this helps with your particular problem.
Dec 05, 2010 | Philips Magnavox 42MF521D/37 Television
I can get a picture , but no sound on the TV . What am I doing wrong?
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
easyab
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
No sound on certain channels
Hi leelee, some cable and air signal channels have a separate audio program in the signal(commonly known as SAP) it may be that the SAP is activated or turned ON in your TV. This no sound condition only shows up on those channels that have the provision for it, but the signal is not being transmitted, that's why you have no sound on those channels. You will have to look for the sound key on your remote control and deactivated from there, or you might have to actually select the menu and scroll down to audio features, it is sure that you will find the SAP feature turned on. Good Luck
Apr 20, 2010 | Astar LTV-3201 32 in. LCD Television
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
Tv audio feed
You most likely have the SAP mode activated. Look for a button on your remote or an item in the on-screen menus of your television called MTS or SAP. You want to set this to "Normal" or "Stereo" (or even "MONO") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you will hear other audio. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed.
Feb 14, 2008 | Televison & Video
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
64 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
