Apple iPhone 5S Logo
A
Anonymous Posted on Aug 25, 2014
How to turn off apps on iphone - Apple iPhone 5S
Richard Nagy
Level 2:
New Friend:
  • Expert 44 Answers
  • Posted on Aug 26, 2014
 Richard Nagy
Expert
Level 2:
New Friend:
Answers
44
Questions
Helped
4287
Points
102
Hard to understand what you actually need?!
You either want to close the app or to delete it?
-to close an app you doubletap the home button and slide the app you want to close, off the screen with a fingergesture from bottom to top of the screen!
-to delete an app, you hold down the apps icon until it starts to wiggle. Once they wiggle, you tap on the "x" in the app icons corner and you'll be asked to confirm the operation.
Why can I not make the BBC Radio app work on my iphone 4. It did work well for some months but now even when I have full strength signal on 3g via ee it simply hunts and will not start. Thanks Roger
(Just to be clear, this is the BBC Radio app, right? If your problem is the BBC News app, I may have a different suggestion.)
Do you have the latest version of the app? It appears that BBC Radio just updated the app a week ago on 31July2014 (Version 1.5.3), but it requires iOS 6.0 or later and is optimized for iPhone 5. I see you have an iPhone 4.
Do you have iOS 6 on your phone? And do you have the latest version of the app?
iOS 6 is supposedly completely compatible with iPhone 4s, and it is also supposedly compatible with iPhone 4 except iOS 6 on:
  • iPhone 4, does not support:
    • Siri
    • Maps flyover
    • Turn-by-turn navigation
    • FaceTime on 3G
    • Hearing aid support
So, it seems to me that this app should still work on your phone, unless you don't have the proper operating system or you haven't upgraded to the new version.
(the info below is copied and pasted for your viewing)
What's New in Version 1.5.3 FIXED - problem with automatically finding your local station
Please note that you can also choose any local station from the option beneath the dial after turning it to 'Find Local Radio'. You can even add up to 3 selected local stations to the dial using the Edit function.
Compatibility: Requires iOS 6.0 or later. Compatible with iPhone, iPad, and iPod touch. This app is optimized for iPhone 5.
Camera is not working
How to Fix the iOS 11 Camera Not Working
1. Close the Camera App completely.
If you find problems with the iOS 11 camera app during usage, close the app from the App Switcher and then open it again.
For most iPhone models that have a Home button, to completely close the camera app, double tap the Home button to bring out the App Switcher, and then swipe the Camera app up to close it completely.
For iPhone X users, swipe up from the bottom of the screen and pause in the center of the screen to open the App Switcher, and the press and hold the Camera app until there's a Close button on the app, then you can tap on the button or swipe up to completely shut down the camera.
2. Restart your iPhone.
Sometimes small issues like app crashes could be fixed by simply rebooting your iPhone. It's a common solution for a lot of bugs and errors on iPhone and a lot of other electronic products. So when you find an iOS 11 camera bug, instead of getting frustrated, try restarting your iPhone first and see if it gets back to normal.
Press and hold the Power button on your iPhone until the Slide to Power Off bar appear. Slide to turn off your iPhone and then press the Power button again after it's been completely shut down to turn it back on.
To turn off iPhone X, press and hold the Side button and one of the Volume buttons at the same time. And then the Slide to Power Off bar would appear.
3. Reset iPhone Settings
If restarting your iPhone doesn't work, try resetting all the settings on your iPhone. It will only reset the system settings and won't damage your person data like photos and messages.
Go to Settings>General>Reset and tap on Reset All Settings.
4. Check for new iOS Updates
Usually if there's a bug in the old version, Apple would have the bug fixed in the latest update. So check and see if there's any update available and update immediately when you can.
Go to Settings>General>Software Update to check for the latest update.
5. Check if you have run out of storage space
One possible reason why you can't take a picture with your camera is that you may have used up your storage space and there's none left for more photos. Go check and see if that's the reason.
Go to Settings>About>Available and see how much space is left on your iPhone.
For more details, check: iOS 11 Camera Not Working:How to Fix
2answers
Iphone 4 battery
If your iPhone battery gets low quick, try disabling features within your iPhone which may help increase battery life.
1. Decrease the screen brightness of your phone.
2. Turn off 3G when not in use ( 3G can decrease the battery life greatly )
3. Turn of Location Services in Settings. ( GPS can decrease bettery life greatly )
4. Turn off bluetooth.
5. Charge your iPhone up to 80% everytime and then stop charging. ( Studies show that charging up to 80% everytime can help increase the life span of your iPhone battery )
1helpful
2answers
My phone is freezing offend. Some of my apps won't open even when I take them off and put them back in my phone. Also my new apps are downloading really slowly. I have a 3gs by the way
I used to have an iPhone and my phone froze once before and i couldn't turn it off at all, so my friend showed me a little trick.
If your phone freezes again and cannot turn it off by just the power button, then click the power and home button at the same time.
Then, once you turn it back on, it should be back to normal.
With the apps, if you don't already do this, you need to update them regularly. You can find it in the appstore and it automatically update your apps. It also depends on how big the actual app is. Ex: If you have a 15.3 or 16.3 MB app, then it will be slow 'cause it's bigger than let's say a 5.7 KB app.
If all of your apps are in KB, then it should be working fine.
3answers
How do I get my apps from my iPhone & iPad to my iPad mini
If you want to sync new apps to iPhone and iPad, you can take advantage of the "Automatic Downloads" function of iTunes. You only need to tap Settings > iTunes & App Store, and locate AUTOMATIC DOWNLOADS, then turn on Apps and Updates. Finish the steps on your iPhone and iPad so that you can get apps on the other devices when you finish a download on one device. You can also take advantage of the third-party iPhone transfer software, Leawo iTransfer, to sync iPhone apps to iPad. The software can transfer files among iOS devices, iTunes and PCs, and it transfers app data when users want to transfer apps. The following guidance will show you how to sync iPhone apps to iPad, and you can download this software and have a try. Download Leawo iTransfer ' Leawo iTransfer for Mac and install it.
Step 1. Run Leawo iTransfer and connect both device to computer with USB cable. Then your devices will be shown on the main interface of the software.
Step 2. Click your iPhone and choose Apps in the left sidebar. The contents will show up in the right part.
Step 3. Select the apps you want to transfer, and click the transfer button at the right bottom.
Step 4. Check Transfer to List and choose iPad as the target. Then click Transfer Now. Then the iPhone apps you selected will be transferred to iPad in several minutes.
select-apps-to-transfer-from-iphone-to-ipad-l4dxfq00cssffurya0z2o1pk-3-0_0.png For more detail, check: How to Sync iPhone Apps to iPad
1helpful
2answers
The sound stopped working on the Angry Birds I bought on my iPhone. Any help?
You can try closing the app, and reopen the app again.
Restart your iphone and reopen the app.
Re-download the app again, and restart the app.
Check if you have silent turn on.
Mar 05, 2011 • iPhone Apps
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
