Question about Apple iPhone 4S
Can't get wifi to turn on... on an iphone 4s - Apple iPhone 4S
David Payne
    Top Expert:
  • Apple Master
  • 14,162 Answers
let me know if you need any more help on this.
Posted on Nov 11, 2014
madan185
    New Friend:
  • 23 Answers
On menu what colour it is.
Grey?
Then it is a hard ware issue which is very easy to repair.
You need to heat a specific point on the mother board.
There is a tuto on youtube.
Posted on Sep 01, 2014
2 Related Answers
Tim Digibrain
  • 846 Answers
SOURCE: wifi grey area on iphone 4s
there might be a problem with your logic boardl, it seems to me that your motherboard hould be repaired or replaced. i've seen that you can reflow (resolder) the wifi chip which sometimes gets knocked loose. you can venture out and do it yourself.
if you look for repair guides online for a motherboard replacement you will find something. I work for company that does iPHone repair in NYC and we do this repair frequently.
Posted on Dec 01, 2013
arky241640
D & B Enterprises
  • 778 Answers
SOURCE: iPhone 4S Issues/Will Not Turn On
Hello, First check to see that your power cord is working to charge your unit. Then remove the battery and let set for 2 mins and then put back into unit. If this doesn't fix then you will have too call cust service or tech support for iphone and work with them. May have too send in too have repaired.
Posted on May 17, 2014
I have an iPhone 4s with iOS 7.1.2. Some apps are only compatible with iOS 8.0 or later. Is it possible to update?
Yeah it is possible to update over wifi or through iTunes.
your iPhone 4s will be upgrade-able to iOS 9.3.5
Jan 18, 2017 | Apple iPhone 4S
My wifi wont turn on my iphone 4S why
common problem with iphone 4s. Means your wifi chip is disconnected from circuit board or defective. Some small iphone shops fix it by resoldering, but under some conditions it may happen again. High/low temperatures, drops and so on. If phone is still under warranty - apple will replace it free.
Sep 18, 2014 | Apple Iphone 4s latest Model - 16gb -...
How do I connect to WiFi on my Apple iPHone 4s?
Try settings - general - reset - reset network settings
Then try to look for available wifi networks again. If that doesn't work check your router has wifi switched on
If that doesn't work it may be that your wifi antenna in the iPhone is faulty
Aug 22, 2014 | Apple iPhone 4S
Iphone 4s will not access wifi
Try to do factory or hard reset
Apr 07, 2014 | Cell Phones
Wifi isnt working
this is a common fault on these phone you can get them repaired but it will cost you a lot of money to repair it
Mar 08, 2018 | Apple iPhone Cell Phones
Iphone 4s wifi on/off
defective wifi unit in the phone. time to get a new phone as they don't fix those.
(similar type problem in my samsung, galaxy, S4. the tech at the booth asked me how i kept it running this long.... had it 6-7 years now....)
FYI: cellphones are designed for obsolescence - within 3-4 years, the battery will fail - if nothing else does - and the batteries are no longer replaceable by a user.
Mar 08, 2018 | Computers & Internet
My iphone 4s will connect to my wifi but cant download anything new - yet works fine on 3G
check the settings of the wifi ( make sure thats DHCP) in the wifi menu
good luck
Feb 13, 2013 | Apple iPhone 3G
Wifi button does not work on my iphone 4s
Try to reset all your settings - before doing this Backup all data
2nd - try to restore it (Warning) You must have a Factory Unlock before Restoring
3rd - if those Solution doesn't fix your problem better visit your nearest apple center. It's a hardware proble - wifi module
Jan 13, 2013 | Apple iPhone Smartphone
Apple iPhone 4S Logo
87 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
