Replaced control board and panel. unit runs (fans lights etc), but it is not cooling. suffered a neutral line failure from electrical panel
With this particle number you gave there are over 40 different models. So I seek a better model number or a complete number to assist you better. Some models had a inverter to control the compressor and I have seen failure due to heat or surges. But without a model number to verify I can't and won't direct you on a fish hunt without the correct information. Get back to me with more information please.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: compressor runs, very little cooling, internal fan not running
You will need to unplug refrigerator and open plane inside freezer to see if fan is stuck or burned out. If freezer is frozen over with ice you will need to warm the ice for removal. Let me know, when you are ready, Sea Breeze
SOURCE: Kitchen Aid refrigerator KSRS251 - not
Sir Good Afternoon..
the problem of your refrigerator is lack of Freun gas
Bring it for Refrigerators Specialist because they are the to put that Freun gas..thanks
SOURCE: My compressor cooling fan quit- the compressor
The problem is most likely the condensor fan motor is starting to fail. This is easy to check, First remove the back cover and when the compressor is running you should have voltage going to the fan motor if you do the fan motor needs replacing if not then the main board would be at fault here is a link that should help http://appliancehelponline.com/refercondenserfan.html
SOURCE: Kitchen Aid side by side
Fridge section not cooling and fan is not running.The fan should actually run, then only fridge section will get cold.
The
working procedure of this unit is as follows: --- The compressor starts then it
cools the freezer section. When the freezer reaches its cooling level the
defrost cycle starts functioning. In this cycle the fan in the freezer section
starts running and the cool air in the freezer section is passed to the fridge
section and the fridge section gets cold. The air from freezer to refrigerator
passes from the section, in that section the damper is located.--------- But if fan is not starting to run, then how will cold air from freezer will get to the fridge section.They will just remain in freezer section and freezer will get bit more cool then required.---------
In some cases its seen, that freezer section gets over frosted and ice gets collected on the freezer fan too.And this causes problem.--------------
So first thing you try is , perform,
manual defrost reset procedure.--------- The manual defrost
reset procedure is as follows : ---- ----------- This should help.
Thanks.Helpmech.
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice
collected on the coils and in the freezer section will get melted.
Clean the water from the sections. Then Connect the power cord of the unit to
main power outlet after 24 hours/.Then set the temperature to normal in both
fridge and freezer section. Then check, if still the fan is not starting to run in few hours then fan motor needs to be replaced.Its easy replacement.--------- Then see if the fridge section is getting cold or not.If still the fridge section is not getting cold with freezer fan running, then problem is defrost board.It has to be replaced.-------
SOURCE: My Kitchen Aid Model KSRG27FKWH04 will not cool
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
