-Providing that the image shown is the tripod you own..., the top leg lock levers on each leg is designed to lock the spreader angle of each leg.
-If this is not holding the leg at the correct angle...., either you are putting more weight on it than it was designed to hold..., or the 'cam' on the various locks has worn.
-A 'stop gap' fix for this problem is to insert a very thin wedge between the lever & the leg tube..., thus providing a greater amount of pressure on the tube, (this would need to be done every time the tripod is set up).
-Replacement parts are not available for this tripod & they were not designed to be user serviceable ...., sorry!!!
Peter
SOURCE: One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
SOURCE: DV7000 tripod locking screws for legs and for
Hi, Folks!
I just cracked the Velbon's DV-700 tripod head mounting screw, that is on the top of the extending column. I need a replacement for this. Screw is on the top of the column.
Any suggestions?
Thank's in advance
