On the Yaesu FTM-400, if the Bluetooth pairing has gotten messed up, can the BU-2 module be reset? The problem is, once the BU-2 has been paired with a headset, if that headset is reset or otherwise forgets its pairings, the BU-2 refuses to re-pair with it. Presumably the radio believes it is still paired with the headset, although the headset has forgotten the radio. There is an awkward workaround: The BU-2 module remembers only the last eight headsets it was paired with. So if you pair eight new headsets, the BU-2 will forget the original messed-up headset, and will now happily re-pair with it. Of course, at that point it's also paired with seven other headsets you or your friends had laying around. Has anyone discovered a better way to reset the BU-2? I've been using my Vxi BlueParrot B250-XT+ with the FTM-400 for a couple months. I accidentally reset the headset, and now the radio refuses to pair with it. This happened previously when I first got the radio, and I discovered the eight-headset trick. It's just a pain to dig up that many headsets, and I'm looking for a better solution.
I have the same issue for a long time. Can't find any information from the internet. Eventually, just tried to find in Japeness and find this manual.http://www.yaesu.com/jp/manuals/yaesu_m/...
Translate with google can understand how it works. Basically, power off the radio. Press the little button for 5 Sec while turning on the radio. This will reset all the paring on your BU-2. FYR http://www.yaesu.com/jp/manuals/yaesu_m/BU-2_J2.pdf
Testimonial: "Excellent, thank you @JCalvin!! I can confirm this technique works as described. After performing the BU-2 reset, I successfully re-paired my (formerly-ignored) Vxi headset."
@JCalvin you are a lifesaver! I did this with the BU-2 bluetooth card in my FTM-10R/E and I was able to re-pair my Sena SMH10 headset (model number dropping for SEO so some poor schlub doesn't have to go through what I did) successfully. Yaesu US technical support didn't even know this trick, so you're one up on them! ;)
SOURCE: Paired with old phone, can't pair with new phone.
have ya phone ready to almost pair. Then on the 850 ear piece press the call button until lit and then open boom up and press the phone pairing ok button and the 850 should work. waaala!
See how easy that was.
SOURCE: cannot pair headset with phone
Morning
After i reset the headset, the passcode "0000" allowed the headset to pair with my phone.
Thanks for the info that was posted as it helped me solve my problem.
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
SOURCE: bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
I have the same issue for a long time. Can't find any information from the internet. Eventually, just tried to find in Japeness and find this manual.http://www.yaesu.com/jp/manuals/yaesu_m/... Translate with google can understand how it works. Basically, power off the radio. Press the little button for 5 Sec while turning on the radio. FYR
