Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
What does U81 mean - Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
Posted by RICHARD RIORDAN on
dross166
    New Friend:
    Problem Solver:
  • 9 Answers
It could mean there is a fault on one of the circuit boards. See
http://www.avforums.com/threads/panasonic-dmr-ex75-85-u81-error-repaired-solved.1486954/
Posted on Aug 29, 2014
1helpful
What does U81 Mean on my DMR-EX75
Just make it a factory reset. Refer its user manual for details. Unplug it from AC mains.
U81 is permanently on the screen, I cant get the TV listing menu, nor can I get it to record, can you help?
U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter'.
This error can be caused by a number of different reasons but one of the most common is a software / firmware problem relating to the Freeview part of the unit.
If you turn the unit off for 30 minutes it should reset the fault.
At this point to need to check what version of firmware you have installed and then check the Panasonic website for your country for the latest version.
1helpful
U81 error up Do I have to take it to a electrical repairer or is there anything i can do ?
I posted a suggestion a couple of months ago about a similar Panasonic DVD recorder (model DMR-EX78EB) with this exact problem:
This is one of several error codes generated by the main microprocessor IC which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
The U81 and U80 codes don't mean anything in particular because the corruption error(s) could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error codes' in any device.
U81 means (in technical terms) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Certainly worth investigating at least; and you should not need to purchase a new unit. Go with the quote first - then decide on a further course of action.
My dmr-e50 ca not play any disc it display dvd drive eror
What is the error code being displayed? is it U81 U61 or U99? U61 is likely to be a DVD drive error. U99 is an electrical problem, while U81 is a microprocessor feedback information error. Your best option is to submit this recorder to a qualified service technician in an authorised Panasonic workshop, for a quote, and a second opinion on the likely repair costs and/or parts involved. (it helps to be more specific when posting questions here about DVD drive faults so we can advise people properly on the best course of action to solve the problem (however a few consumers do not know what device error codes are and what they mean; this is understandable in many cases).
The cost to fix this unit depends where you go and whom you deal with. It is up to you, but be warned; if the unit needs a new DVD drive, this could prove expensive.
1helpful
My DVD RECORDER MODEL NO DMR-EX75EB, THE CODE U81 KEEPS COMING UP WHEN I SWITCH ON MY RECORDER, ALSO I CANNOT GET INTO MY SETTINGS TO SEE IF I CAN FIX IT. THANK YOU
This seems to be a common fault with many Panasonic DVD recorders of the DMR-EX series.
This is one of several error codes generated by the main microprocessor IC in the unit which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used (if available) and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
I posted this 'advice' for this (and a couple of similar models) previously. The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Because of the malfunction, the user settings and options are inaccessible, and there is no official user-reset option on this or any model of the series to clear this particular error.
Certainly worth investigating at least, as Panasonic usually make great products.
It's up to you as to what you decide to do from here.
3helpful
DVD recorder DMR-EX78EB - Keeps showinf error message 'U81' on display. This means that it does not perform set recordings. What causes this please and how can we fix it as I am fed up with finding...
I posted this 'advice' for this (and a similar) model previously. The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Certainly worth investigating at least.
8helpful
My DMR EX75EB it fails to operate and a code of U81 comes up.
The U81 and U80 codes don't mean anything in particular because the corruption error could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error code' in any device.
I posted this 'advice' for this model previously. The DMR-EX75 and DMR-EX85 are prone to U81 - which is a common error code.
3helpful
My panasonic dmrex75 has an error U81 on it. Does anyone know what this means?
This is one of several error codes generated by the main microprocessor IC which are tripped by corruption, preventing proper operation and which may require the processor to be reset or replaced.
The U81 and U80 codes don't mean anything really because the corruption error could be caused by any one of a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error code' in any device.
Nevertheless, U81 means (in technical terminology) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
Either way, this is not something an end-user should undertake to repair themselves; it should really go to an authorised service centre. The cost depends on the parts used and the labour, however, it is not unfixable.
1helpful
2answers
The error message U81 comes on everytme I turn on the player. It also want play DVD's or allow me to change modes?
U81 is an error message indicating a microprocessor communications error/problem. This can be from a host of issues; probably time to take the unit in for service.
4helpful
I have an error message U81. The DVD recorder
These are error codes generated by the main microprocessor which are tripped by corruption, preventing it's operation and which requires the processor to be reset.
The codes do not actually mean anything at all because the corruption error potentially has a great many possible causes.
It does not point to any specific fault as such.
U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter' but I dare say if Panasonic told you that , you would be no further forward.
Corruption can arise for many different reasons .. and is not surprising in a box that has an aerial feeding endless streams of complex data into it, has a mains connection with interference on it, has two internal data storage and retrieval systems, either of which can be problematic... and sits permanently bathed in electrical and radio frequency fields of varying intensity.
Causes can be difficult to identify and may be internal or external.
Such problems may be exacerbated during the transitional phase of the DSO [ Digital Switch Over ]
In practice, all one can do is follow good practices:
Don't stack gear - or give it plenty ventilation if you do.
Ensure good clean mains supplies.
Ensure a properly installed aerial system with sound connectors and adequate screening.... etc.
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
