Question about BuySKU CHUNGHOP RM-139ES Universal TV Television Remote Controller Black
I have a tv set make Hisense 32 inches . I bought a universal remote control RM-139ES but the 'set' key does not illuminate when I hold it. Please help me d
How to execute its setup for my t.v make Hisense 32 inches
Posted by ravin sunkur on
    Top Expert:
  • BuySKU Master
  • 76,455 Answers
0281,0188,0183.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Aug 25, 2014
I have a brand new Hisense H3 32" tv that came w/ a bad remote. I can't turn it on so I can't use a universal remote. Hisense says no remote replacement so what do I do????
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Sep 27, 2015 | Hisense Televison & Video
Remote control code for matrix
Aug 16, 2014 | BuySKU CHUNGHOP RM-139ES Universal TV...
IS IT POSSIBLE TO GET THE CODES FOR A DIXON REMOTE RM-L600, MY TV IS A LG 32LK310 ?
Write your answer...I have the manual book but its difficult to set my Dixon RM-L600 Universal Remote Control please help me how to set it on My Hisense 32LD
May 27, 2013 | Televison & Video
CODE FOR TV PANASONIC, CHUNGHOP RM 139ES
020, 001, 002, 014, 015, 021, 022, 059, 066, 423
Jan 23, 2013 | BuySKU CHUNGHOP RM-139ES Universal TV...
Chunghop rm-309es code for Sony
Check these codes:
0128 0013 0002 0071 0380
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
May 12, 2012 | Universal Remote Control Remote Control
Need a universal remote control code for Hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Code chunghop RM 139ES for TV Mitsubishi?
The Mitsubishi TV codes for this remote are 011 and 051.
Programming instructions:
1. Switch on the TV
2. Press the "SET" button in the top-left corner of your Chunghop remote until the LED next to the "SET" button illuminates.
3. Enter the first code above 0 1 1 using the numerical buttons on the remote.
The LED next to the "SET" button will go out if you have correctly entered a code.
4. Test the remote with the TV. If it doesn't work - or doesn't operate the TV functions as you would expect - repeat the above steps for the other code.
Please note: Not all universal remotes will work with all TVs.
If the codes above don't work please post back for further assistance. It may be that your remote wont work with your TV or you may need to run the code search feature of the remote to find the correct code.
Hope this helps.
Regards,
BElectric
Dec 30, 2010 | Televison & Video
I have a chunghop universal remote, RM-133E and i need the 3 digit code for an LG tv please. Thanx.
I could not find the code, but here is a solution that should work. Please give me good rating
1. Manually switch on the TV set, and aim the remote control at the TV set, as shown in the figure:
2. Hold the "SET" key until the indicator light illuminates.
3. Repeat to press the "VOLUME +" key and see whether a volume symbol appears on the TV screen.
4. Upon appearance of the volume symbol, press the "SET" key immediately, and then the
indicator light goes out.Setting is finished.
5. Test whether the keys on the remote control function well; If keying does not work, reset from Step 2.
Jul 01, 2009 | Universal Remote Control Remote Control
Remote control RM-810
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching
1. Turn on the TV
2. Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once.
3. Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on.
4. Release both buttons. The indicator light will flash constantly indicating the automatic search mode.
5. After the indicator light illuminates, release the two keys simultaneously.
6. If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller
7. Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
BuySKU CHUNGHOP RM-139ES Universal TV Television Remote Controller Black Logo
203 people viewed this question
Top BuySKU Televison & Video Experts
Marvin
Marvin
Are you a BuySKU Televison and Video Expert? Answer questions, earn points and help others
