Question about InFocus LP70+ Multimedia Projector
How to fix dim picture?
I got a used Infocus LP70+. The lamp is brand new, but still picture is very dim. Brightness adjustment doesn't help much. The picture is sharp and good colors. DMD Chip replacement help in this situation? Or is it just that color wheel is needed to replace?(sorry my bad english... :) )
5 Related Answers
geekpdx
SOURCE: Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Posted on Nov 21, 2007
Anonymous
  • 149 Answers
SOURCE: Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Posted on Oct 27, 2008
projdoc
jasbo
  • 2239 Answers
SOURCE: lp70 flickers and color wheel chirps at the same
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Posted on Aug 10, 2009
Anonymous
  • 17 Answers
SOURCE: the color wheel on my infocus 7200 is bad and getting worse.
Have you cleaned the inside of the case out? It may be dusty and dirty. UNPLUG FIRST! If you can carefully remove the cover and inspect. Use a vacuum in reverse or canned air to blow out loose dust and debris. Clean or replace any projector filters.
Posted on Sep 10, 2009
Testimonial: "Thank you Tom! This has helped tremendously"
Anonymous
  • 167 Answers
SOURCE: InFocus LP70 color problem
No it's not the color wheel. If the color wheel stalls the lamp will shut off immediately which is a built in protection mechanism. On the LP70 and 70+ there is a multi pin connector inside located at the rear lower left of the projector. This connector connects the main board to the DLP engine electronics. This connector is horizontal and approx 2 1/4" wide and 1/4" thick and about 100 pins. I have seen this connector not seated completely and many various video artifacts occur (even the one you describe) If you or someone you know is electro-mechanically savvy it's not difficult to open the projector and make sure this connector is seated properly.
You will need a TORX T8 screw driver.
Cheers
Posted on Jan 16, 2010
How can i fix the brightnees in my 61md10
there is a menu setting for best pix or longer lamp life.
Also, turn up brightness of picture settings(different menu)
Also use daylight setting, vibrant, (different menu).
Bulbs dim over time and dust can accumulate on projector lens, mirrors and (not so much on mine) back of screen.
New lamps tend to melt a plastic lens in light engine, a dark shadow may start to appear upper left or center. this started to happen to me with new bulb, (Ebay O.E.M. supposedly $114). I switched back to original lamp hopefully to slow the burn till I can tacklle a repair. Take a look at this website. Hope that helps.
http://www.61md10.org/modules/newbb/viewtopic.php?post_id=2651
Mar 10, 2010 | InFocus ScreenPlay 61" Rear Projection...
Message reads failure to srike lamp. bulb is less
that ones are total ****... seems like lamp is broken .. my advice would be get a new projector(not LP70) other that get a new lamp...
Mar 02, 2010 | InFocus LP70+ Multimedia Projector
Why does my projector Infocus 7205 says constantly replace lamp and we have a new lamp? Thanks for helping...
On the projector you will see 2 buttons for adjusting the brightness, with the projector on press both the brightness up and down at the same time.
Hold them both pressed for 10 seconds. This will reset the lamp timer.
Take Care!
Nov 13, 2009 | InFocus ScreenPlay 7205 Multimedia...
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
Image is dim. How do I adjust brightness
You can adjust the brightness through the user menu, under the picture option. You might want to look at your bulb. It might be time to replace the lamp.
Sep 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus LP840 pcture brightness problem.
Even though the lamp looks bright, most likely it is the problem. My 850 had a similar problem and it was the lamp.
Cheers
Jan 13, 2009 | InFocus LP840 Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
InFocus Proxima UltraLight LS1 LCD Projector
There could be several reasons for this problem.
1. New lamp needed.
2. New lamp did not fix? Could be mirror tunnel behind the color wheel than can collapse causing "dim" light source or dark lines.
3. All items "greyed" out caused when the unit does not sense a source input, ie computer or tv tuner. After connecting to a source, you should be able to go and adjust contrast and/or brightness settings
Oct 01, 2007 | InFocus X1 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
147 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
