Question about Kenmore 43142 Front Load Washer
My kenmore front loading washing machine will not spin?
5 Related Answers
Anonymous
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
Anonymous
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
Paul
  • 224 Answers
SOURCE: my washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Posted on Jan 20, 2009
Anonymous
  • 106 Answers
SOURCE: Washing machine won't do final spin.
Remove the front lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out, refit carefully and give the washer another try. The companies dont tell you how to do it, for their techs then won't make any money. A tech to clean your filter!!!?? $$$
You're free to rate me............not that i get anything. Happy laundry!!
Posted on Mar 01, 2009
Anonymous
  • 256 Answers
SOURCE: Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Posted on Feb 22, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore series 70 washer will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
My kenmore he2t 8540911 drum will not spin.all of the time and leave the clothes wet.
heatman101
Aug 09, 2011 | Kenmore 43142 Front Load Washer
My washing machine will wash, but not spin. What should I check first? Kenmore 80 series
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 15, 2011 | Kenmore Washing Machines
Kenmore supercapacity 3.5 , model 417.44052400 drum does't spin during the rinse and spin cycle
heatman101
Mar 05, 2011 | Kenmore Washing Machines
Kenmore frontloader runs great until it gets to spin and it doesn't
heatman101
Feb 23, 2011 | Kenmore 44102 Front Load Washer
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
My he2 kenmore clothes washer does not go into spin cycle
heatman101
Sep 08, 2010 | Kenmore HE2 Plus Front Load Washer
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore 43142 Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
