SOURCE: FL1 fault code
Definition of FL1 = Water flow problem, inhibited or pressure switch
malfunction. Check for proper spa water level and ensure pump is
primed. Check for clogged filter.
Its likely to be your pressure switch (screws into heater tube, usually two wires) If this is blocked or has failed the heater will not turn on.
