Question about KitchenAid Kitchen Aid KEBS277SWH Double Wall Ovens
Why the cooling fan does not work on one the upper over of KEBS278
The blower/cooling fan does not turn on.
Fix Your Board
    Guru:
  • 310 Answers
First check that the fan itself has not failed. If the fan and wiring are ok, your EOC (electronic oven control) has failed. This is NLA (no longer availabe). The Whirlpool part number is 3187895. This can be rebuilt: See:
http://www.fixyourboard.com/boards/3187895.html
Posted on Sep 08, 2015
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 • Bosch Ovens
I have F1 - blower error. Also, it give cooling down error. It works at 208 but not at 240. And i am not able to change it to 208 all time. Any solution please.
Ur using Turbo chef or merry Chef oven? Ur error was cause by fan blower for ur heater to circulate hot air inside the cavity for toasting.. Maybe it's now turning or stuck up. What's the. Model?
Jun 09, 2016 • Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
I have a Thermador Model C302U wall oven the fan on the uppper oven starts and then stops and I get the F34 code I am thinking to replace the motor but I want to know if there are other things I should...
When that fan starts up the air pushes against an air switch and that tells the board the fan is blowing. The stove uses a DAC system that relies on switchs to confirm the operations of the fan. the DAC control uses signal voltage to detect switch function. The air switches must physically close by air movement from the cooling blowers before the oven proceeds into a bake or broil mode. Reason being f the cooling motor does not function and the oven goes into a bake or broil mode, the oven will overheat and could damage the fancy smancy over engineered piece of garbage electronic components. My opinion. This is not for the DIY unless you are a TV repairman.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
Error message on JJW9530DDS Jenn-air wall oven is 4d21
no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
6answers
Blower remains on when oven is turned off
yes it is normal i have one and it has been doing that sine i brought it i took it a part and there is nout wrong with it so yer its fine
KitchenAid Kitchen Aid KEBS277SWH Double Wall Ovens Logo
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
