You must have put the mode dial on 'SCN' and selected an in-built effect. Set the camera to another mode (iAuto, Auto, P, S, A, M) and it should work well.
On your camera, look for settings. You must have set it on "Large" or "Max" picture quality. Thus making your 'normal' 800kb into a more better quality.
On your laptop/computer try to open it in a image editor and change the resolution of the picture.
Hi, This kind of problem occurs when ccd imager chip got bad in camera. Let me know model number of your Sony camera to provide you more info to solve its issue. Thanks.
Hi there its depend on the camera type. I mean some time the photo identity no showing the date. For example Sony Camera showing the photo no DSC XXX01012010. Its mean its taken 01 JAN 2010. Some camera mention normal photo identity. But as per your requirement is not possible to change the camera software setting. You have to identify by Serial no. I hope i explain you the full things. If you want to know more then let me know. I try to batter explanation then, Thanks.
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
just change the resolution set the camera on photo mode then press trash button, it should display the resolutions i recomend 1.3 megapixels for normal pictures, when you need the high resolution change it to better also if you use the options of the photo mode you can change from fine to normal picture quality
