Question about Metra Ford F 150 Truck 1996 Up
What purpose does the fan clutch serve and how does it work?
Truck heats up in hot temperatures when idling.
Robert Struzinski
    Sergeant:
  • 182 Answers
The idea of the clutch fan is that when your vehicle gets hot the clutch is designed to start gripping the fan blade more to allow the fan to spin faster as the temperature risies. Then when you are moving fast the clutch will disengage and free wheel letting the air move freely past it. The fan would actually be moving slower than the air rushing into the engine compartment from the speed of the car and would be blocking the flow.
The most important part of the clutch fan that makes it work properly is the Shroud, it attaches to the radiator and it directs the heat toward the clutch properly. Without the correct shroud the clutch is useless and will not function properly.
Posted on Nov 16, 2014
Will the bad waterpump on a 2003 pontiac aztek cause the temperature to overheat sometimes but run good others?
the water pump is working
the problem indicates blocked radiator cores preventing full flow at high rpm
have it flow tested by an accredited radiator shop or just fit a new radiator
Jul 13, 2017 | 2001 Pontiac Aztek
2003 chev. silverado During extreme temps the
I WOULD SUGGEST A NEW RADIATOR ..NOT PROPER FLOW WILL CAUSE THAT.MAKE SURE YOU HAVE FRESH ANTI FREEZE.
Aug 08, 2011 | 2003 Chevrolet Silverado 1500
I have a 74 gmc pu with an 87 350 motor that i put in. I put new edelbrock itake, carb, headers ,new pipe and mufflers, wires ,plugs .It starts, idles, and drives good even at normal or cold operating...
The fuel mixture is wrong because either the carb is badly adjusted or the choke doesn't open fully when the engine is hot.
Take the carb apart and check every single component, starting with the choke plates and the level in the bowls.
Jul 30, 2011 | Chevrolet C2500 Cars & Trucks
My truck runs fine for about 15 miles. when it is hot outside the temp starts to rise....has a new water pump on it,new coolant....how can i tell if the fan clutch is bad?
Have you checked the thermastat too because this part also goes bad and does not open up at its temperature range to allows the coolant to go through the engine to cool it off. Usually when the fan comes on is at a much higher engine temperature so you would have to run the truck just by having it idle for 5 or 10 minutes so the engine gets hot and you should see if the fans come on to help cool the engine down to its normal temps.
Jun 02, 2011 | 2000 Chevrolet Silverado
Over heats while stop iat traffic light radiator fluid is full i think the fan is not working
I think you are right. Let the car idle with the hood up as you watch to see if the fan kicks in when the temperature goes over normal.
Dec 28, 2010 | 1995 Honda Accord
Temp gauge is in normal, 200 degree, range when starting. Within a few minutes of driving goes up to 250, right below orange line. No leaks found, coolant level appears fine. Any ideas?
250 DEGREES ENGINE GETTING TOO HOT.SOUND LIKE CLUTCH FAN FREEWHEEL.IF CLUTCH FAN DONT LOCK IN OR HAVE RESISTANCE TURNING BY HAND WHEN ENGINE HOT.FAN CLUTCH IS BAD.IF FAN CLUTCH OKAY COOLANT LEVEL CORRECT.I WOULD CHANGE THERMOSTAT FLUSH OUT ENGINE AND RADIATOR.IF ENGINE TEMPERATURE STILL READS 250 DEGREES OVER FLOW JUG OR RESERVOIR NOT BOILING OVER THE COOLANT TEMPERATURE SENSOR FAULTY.
Nov 05, 2010 | 2003 Chevrolet Avalanche
My 2002 xterra has started running hot..code po 217 came on..after gas cap was put on wrong..cleared code put gas cap on right then fine for 2 weeks..when idleing heat gauge rises high..as soon as i rev...
p0217 is coolant over temperature. the fan clutch may be slipping or the thermostat is bad. changing the thermostat would probably be the easiest and most inexpensive fix to determine the problem.
May 09, 2010 | 2003 Nissan Xterra
MY HOT AND COLD METER KEEPS RISING AND FALLING
If the fans are electric, then replace the fan control module.
If the fan is belt driven, replace the fan clutch.
There is a chance that the thermostat is failing, but if the temperature fluctyation occurs during driving, as opposed to stopped and idling, then it's probably the fans.
Dec 18, 2009 | 1998 Oldsmobile Intrigue
The truck is running hot but not always overheating and the a/c causes it to heat up faster. I just changed the thermostat. I would like to use the a/c. there is also no leaks.
When truck running hot, with AC off, try throwing the heater on high heat, high fan & see if gauge starts to go down at all. Ya it might get a little hot inside but good way to test if rad is problem or not. If temperature goes down noticeably, I'd be thinking about a new rad.
Jul 15, 2009 | 1993 Dodge Dakota
GUAGE SHOWS HOT
is it ever low in coolant? i agree with emissionwiz sounds like your getting airpockets do you have heat when this starts?
Nov 09, 2008 | 2002 Chevrolet Avalanche
Metra Ford F 150 Truck 1996 Up Logo
88 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
