Fig. Expedition - Trim Panel Screws shown
Fig. Navigator - Trim Panel Screws shown
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
Fig. Removing door lock actuator
Fig. Removing door lock motor-Sedan
Do not attempt to remove more than one pushpin at a time.
To install:
This procedure applies to both the front and rear door panels.
// 0)
preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i];
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 30;
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog'];
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC';
ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data';
var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Remove the cover from behind the inside door handle by gently pulling it out to release the retaining tabs
Remove the pull cup retaining screw cover and...
... remove the retaining screw from the cup and lift the cup straight up out of the door panel
Remove the two sail panel/speaker grille retaining screws and...
... remove the panel/grille from the door
The door panel is retained to the door by 11 retaining clips
Carefully lift the door panel off of the door and...
... detach the electrical connectors from the switches and remove the panel from the vehicle
