First, make sure that you have a very good signal - check channel 1 audio. Then go to the MENU and 'RESET' to factory settings.
Then call SiriusXM and have them send a 'REFRESH' signal - leave it on channel 1 for about 20 minutes, then check and see if you have Channel #4 - if you do, then dial-up Channel 71 - you should have Sinatra - UNLESS, you have a MUSIC-ONLY subscription, which limits your channels to only the specified ones. But, with XM Select or higher, you should have channel 71 again. Let me know how it goes. Good luck.
SOURCE: "Antenna" Appears on Roady XT Display
I had the same problem, it says antenna when you turn it on. It seems that there is a small wire that stays in the radio side of the socket right in the middle of the socket. This fine wire breaks off . I think there is no known repair for this. I took a piece of fine wire from a wire brush, and poked it into the socket . Had to get one that was thick enough to stay. Then I plugged the antenna into it, it worked.
SOURCE: Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
SOURCE: Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
SOURCE: Delphi Roady xt, cassette adapter problem
I was thinking how can I trick the cassette into keeping the cassette in there because every time I put it in, it just came right back out
This is what I did
Go and find a real cassette and cut out a little piece of the cassette tape and set that aside
Every cassette is different so find a way to attach tape from a real cassette to the cassette part of the cassette adapter
You need to attach the tape so it is flat over the head of the cassette just like in a real cassette, which is the part where the music is transferred, once u get it over the head the cassette deck will think it is a real cassette and it will stay in the deck, the tape doesn't even need to be perfectly flat like in a real cassette tape, it can be all messed up and it will still work but flatter is probably better, so you are just tricking the deck into believing that it is a real cassette, it worked for me and hopefully it will work for you, tell me how it works out
SOURCE: when hitting menu fm frequency does not show on my roady xt
Can be one of two things.The freq. will not show on the menu if the cradle that the radio plugs into is faulty,or if the radio is faulty and thinks that there is something plugged into it's aux. which tells it that you don't need the FM modulator.Try a new cradle first.
