Question about Kenmore Whirlpool Duet Washer Water Motor Pump 12801879
How much is a water pump for a whildpool washer duet
Posted by Rachelle on
Gary R. Kipfer
    Champion:
  • 279 Answers
Go to www.sears.com/parts input your model number and you'll see it listed.
Posted on Aug 31, 2014
Duet washer leaks during use; rinse cycle?
Check the water pump hose connections and the water pumps housing bolts themselves could have loosened from vibration. more likely the hose connections on the pump itself though. Hope this helps.
Feb 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The washer shuts off by itself, a message of "F21" appears on the screen. It happens twice last week. Thank you for your help, Autumn Lin
Hello Autumn,
The F21 error code means the pump has taken longer to drain the water than usually time it takes to drain. Here is what you check to see if something is in the drain pump filter restricting the water flow into the pump. I know i have the Whirrpool Duet washer pictured . Whirlpool makes that washer so other that the name "duet" everything is the same
The most prominent cause of your DUET washer not opening after the cycle is done and door remains locked is going to be a blockage in the drain pump. Here is what to check in the pictures below.oldtech2332_3.jpgoldtech2332_4.jpgStart by unscrewing that just a little and use towel/tupperware tubs and catch the water that will come out. Once all the water is out remove completly and check for a blockage
Aug 18, 2011 | Maytag MHWE300VW Washer
Water drains back through the fill lines.
THE COLD AND HOT WATER CANT GO BACK IN TO THE WATER VALVE ! NOW IF THE DRAIN WATER COMES BACK IN AFTER DRAIN MODE LEFT DRAIN HOSE UP A FOOT TALLER THIN THE WASHER OR CLEAN YOUR PUMP THIRS A CAP ON THE PUMP YOU CAN REMOVE TO CLEAN . NOW IF THE WASHE IS FILLING UP WITH WATER WHEN ITS OFF THE WATER VALVE IS BAD
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I get the error code S02 on my Duet washer. It
02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WATER PUMP ON DUET
Was easy to remove clamps with a pair of Channel-lock pliers
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool warher
This is another pump problem, it will keep pumping if it thinks there is water coming through, pump cycle should only be about 30 seconds.
Oct 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Whirlpool Duet Washer Water Motor Pump 12801879 Logo
46 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
