Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
Not a good idea. Miter saw are too dangerous to be altering them in any way.
Posted on Oct 27, 2014
SOURCE: makita LS1013 miter saw motor runs very slowly
Could be a bearing problem. If the bearings are dry and seizing up they will hinder the motor speed. Alternatively, if they are worn and allowing lateral movement in the motor the armature will rub against the field windings when it all magnatizes (sp?). I would investigate bearings before electrics. Hope this helps, good luck.
Posted on Nov 29, 2008
SOURCE: Need owners manual for a mikita miter saw LS1013
Go to Makitatools.com and on the right side type in your model number and it will take you to a page where you can get the manual or the breakdown. Let me know if I can help further, I work on them everyday/
Posted on Jun 13, 2009
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
SOURCE: makita LS1013 compound saw wont slide,instruction
You may find, you have a lock, button, that needs to be held in, before you can drop the saw to cut.
Posted on Apr 28, 2010
