SOURCE: eciever to hp laptop
If your laptop has a HDMI port then you could conect it to the reciever that way. Else if it doesn't, I would recommend a cable like this http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=666&seq=1&format=2 that will go out of your computer's headphone jack and then into the receiver.
SOURCE: connecting laptop to hd tv
IMake sure that you have the laptop for an VGA OUTPUT. When you toggle between the function keys. When your laptop LCD goes out it is in VGA OUT mode....when you toggle again it should be in LCD/VGA OUT (both TV and laptop should display). You need to set the TV to VGA mode as well...otherwise you might not get an output. If you still have a problem then test on a regular monitor to see if you are getting an output to the monitor
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
SOURCE: How do I connect my Toshiba Laptop to my Sharp Aquos to watch Netflix?
you need to see if you have a pc in (vga )on your tv and then you need to see if your laptop has a VGA out then you need a VGA Video Monitor Cable HD 15 Male to Male cable bettween the lap top and the TV.
then you need to go to control settings on your laptop (depending on what operating system you are running) then display settings-settings and set it to go to your tv .
SOURCE: Sound won't come out of my TV when I connect my laptop to it via HDMI
connect an audio cable from laptop to tv
