Question about Janome Memory Craft 9500 Computerized Sewing Machine
Janome customizer 11000
Have customizer 10000plus ver3.4. Do I need to download customizer 11000,as I have a new laptop and are having great trouble down loading very green at all this cheers Anthea
Posted by Anthea Hamnett on
Anita
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Have you tried customer service for the software of your machine?
sometime it depends on the window your using you might have to keep using your old laptop. I had to revert back to an older model computer in order to continue with my machine but it was a different sewing machine. Check with the cs of you software im sure its cost you a lot. Hope that helps
Posted on Aug 28, 2014
2 Related Answers
Anonymous
  • 8 Answers
SOURCE: Janome Customizer 10000
There are different programs for 350E. I think, you was buy program different.
Posted on Jan 11, 2009
paj42
  • 1116 Answers
SOURCE: I just purchased a Janome CM350E and need Customizer software
You can use any machine embroidery software brand.
There are many that have free trials and demos. Embird is one brand that is very popular.
You start with Embird Studio and then add other programs as you become more knowledgeable about machine embroidery.
All ME software products run on Windows XP, Vista and some are now compatible with W7.
You can find more machine embroidery discussions/questions and answers at sewforum.com
Posted on Mar 25, 2010
I have a new pc with Windows 10 and my digitizer MB V2.0 for a Janome 11000 won't transfer from my old pc nor will the new computer recognize the dongle.
down load the drivers for that model sewing machine from the machine manufacturers web site that are compatible with win 10 operating system
Sep 11, 2018 | Janome Sewing Machines
Where can I buy a Janome 11000 programme for my machine
Search for:
Make Model manual
If you're lucky, you may find one for free.
Mar 20, 2018 | Janome Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Janome memory craft 11000 v2.0 now on windows xp I need to transfer this programme to a new laptop windows 7 it opend but keeps saying that I have
I believe there is a new download to make these work with windows 7.
Go here and scroll down to "customizer 11000 v 1.50" or which ever program you have.
http://content.janome.com/index.cfm/LearningCenter/Software_Updates
Sep 14, 2012 | Janome Sewing Machines
Mar 25, 2010 | Janome Memory Craft 10000
Customizer 11000 does not convert image files to stitch files
I'm assuming you are refering to the auto tracing function of the program. Customiser 11000 is a very limited layout and editing program, it's digitising function is extremely limited.
What is never explained satisfactorily to the purchaser, is the requirement for exceptionally clean artwork. Scanned photographs, colouring book images etc are not clean artwork. You need vector clip art, optomised clip art you find on the web is too "dirty" and needs a great deal of "cleaning" in a graphics program. Use the WMF import function and source a decent supply of WMF clip art. Most commercial clip art collections offer WMF as an option as do the clip art for digitisers sites.
Another reason for your program freezing could be an underpowered video display card, if your computer has a shared graphics card you're underpowered. Also your Ram, Customiser 11000 is a CAD based program which uses a lot of ram playground and a lot of your display cards muscle, whatever the programs specs are, triple them.
Check which version of the program you have, then visit Janome global, select downloads, software , and see if you have the latest version, if not, download the newest version.
Jan 18, 2009 | Janome Memory Craft 10000
Janome customiser 11000
When you backed up you probably only backed up documents. The executable files that make the program work are in program files and folks seldom back up program files. It was pre-installed on your pc? How weird. I believe the only thing you can do now is to go buy Customizer 11000. Check ebay and the yahoogroup sewitsforsale to see if there are any used copies. It's not an expensive program, and frankly, you don't NEED it if you have Embird, which does all Customizer does plus more.
HTH
May 25, 2008 | Janome Memory Craft 10000
Usb drivers
go to driverskit and download it
Feb 07, 2008 | Janome Memory Craft 10000
Formating memory
You need to format the usb stick in the machine itself, don't use a high memory one or one that has a partitioned area. 1 gigabyte or lower. You need to use the set icon on the machine and arrow through the pages to find the Format screen. Select the tab for USB device. Then click yes to the prompts, that installs the correct folder system. Now the software end,open easy design and select machine from the top toolbar, set machine type to 11000. Open a design and use the file drop down menu and select Save As, choose JEF in the file type bar, you will see a button below Save , Delete, called options, click on it, you'll find a list of machines, set it for the 11000. It is that selection that saves the design in the correct format. There are 2 jef formats, the old Jef for the previous machines and the enhanced Jef for the 11000. Now rename the design, open the flash memory menu and in the right hand pane you should see your usb flash drive, if it's the only one you have connected all well and good, if not click on each flash drive to find the correct one.You'll know which one it is,because in the window below you will see an Embf folder, open it, you must always open the Embf folder before writing a design, now some have child files inside, emb, if so open that as well , don't create a new folder it wont be read by the machine. Now write the design to the usb flash drive. Do you have a copy of the PCtools software? if so you need to download the update as it's that software that allows 2 way communication between the machine and the computer. Keep an eye on how many designs you insert into the internal memory, it isnt very big. You shouldnt need to reformat the internal memory,
Jan 08, 2008 | Janome Memory Craft 10000
Janome Memory Craft 9500 Computerized Sewing Machine Logo
187 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
