Does not start in park or neural sometimes
SOURCE: rover 75 v6 starts no problem runs 1000 rpm then
check idle speed sensor on your intake manifold around 700 to 750 rpm is normal ,air temp may efect idle speed .
Posted on Sep 17, 2009
SOURCE: i have problem with my
I recently hear a problem that looks much like yours. It was with a '01
Disco and they too was getting 02 sensor failure codes. Turns out that
the sensors were not installed properly.
Here are some other possible causes and possibilities: Failure of the closed loop control of the exhaust emission system may be
attributable to one of the failure modes indicated below:
1. Mechanical fitting & integrity of the sensor.
2. Sensor open circuit / disconnected.
3. Short circuit to vehicle supply or ground.
4. Lambda ratio outside operating band.
5. Crossed sensors.
6. Contamination from leaded fuel or other sources.
7. Change in sensor characteristic.
8. Harness damage.
9. Air leak into exhaust system (cracked pipe / weld or loose fixings).
If you know what codes are being triggered, send them along and I'll try to help, while could check this:
- DTC_P0133
- DTC_P0141
I hope this helps.
Posted on Sep 09, 2010
SOURCE: rover 75 vehicle starts but will not have acceleration
Hi, Check fuel filter and replace. Check and replace sparkplugs. Check ignition components. coil, wires, distributor for cracks. and then check for codes. Good luck.
Posted on Dec 22, 2011
SOURCE: rover 75 diognostic reports fault on cylinder 3 & 4
that simply means the #3 and #4 misfires. check the resistance of the coil if it is within the range. if not,replace the coils.
the scan tool tells exactly fault.
Posted on Feb 09, 2012
SOURCE: wiring diagram for rover 75 v6
witch one do you need they are broken down in sections
Posted on Jul 15, 2012
Dec 17, 2014 | 2005 Rover 75 2.0
Aug 10, 2014 | 2006 Rover 75 Tourer
Jun 01, 2014 | 2000 Rover 75
Apr 10, 2013 | Cars & Trucks
Jul 15, 2012 | 2000 Rover 75
Feb 09, 2012 | 2000 Rover 75
Sep 17, 2009 | 1999 BMW 323 Series
Apr 23, 2017 | Home Fencing
569 people viewed this question
