I received an email saying that my account has been frozen and I need to update my details within 24hrs. Is this an offical request from Apple is it is a scam could you please advise
SOURCE: iTouch with road runner email
can not vonect to email with itouch tried resetting did not work
SOURCE: My ipod has frozen up
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Basically, move the hold button on the top of the ipod to the on position and then the off position. Next hold the menu button and the center button at the same time for about 10 seconds. The ipod should restart, you should see the apple logo and then it's fixed!
The link is just more detailed instructions.
SOURCE: the computer can't detect the iPod..it only says Apple Ipod help please!
you need to download itunes software for the computer to recognize your ipod and to synchronize your songs. download and install itunes in your computer. Thanks
SOURCE: My iPod 160 GB Classic is stuck with just Apple
Try forcing the iPod into disc mode to restore.
Putting ipod into disc mode
http://support.apple.com/kb/HT1363
Toggle the Hold switch on and off.
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If this does not make the iPod connect to your computer, I would suggest checking out www.rapidrepair.com for further ideas and options to your issue.
SOURCE: I have ben gifted a new ipod apple a1136 but
you can search for manual here
http://support.apple.com/manuals/
theres a box to enter your serial number and it will then find the exact manual for that model
Download the program ActivePrint 4.7 and then follow the instructions on how to set it up.
http://activeprintblog.pocketwatchsoftware.com/
You can't actually print from your Apple iPhone with this program, but it allows you to select whatever documents you wish to print through a host computer and then print them from your own.
Purchase a program called "Automatic Print Emailer" from its official Website.
This program automatically prints all the email from whatever web based or pop accessible email account you use.
Set up on your Apple iPhone to use this program, and then enable "POP" from your email settings.
After you've done that, set up the program to check and print your email messages and attachments automatically.
Buy PrintPocketCE from its official website.
This program prints documents, spreadsheets, and email from your Apple iPhone or any PDA. You need to have a printer which is compatible with this program.
There is a list on the website so that you can find out if your printer is compatible before you purchase this program.
Download the trial version of Print Tools for Outlook, which is a program that automatically prints incoming and outgoing messages (even those with attachments) from your Apple iPhone if you use Microsoft Outlook to send and receive email.
Hope this helps.
