Hisense LCD1504 15 in. Television Logo
Question about Hisense LCD1504 15 in. Television
I have wii5, my hisense tv is picking up butr the tv would not connect to network
The tv shows that it have the wii 5 signal but when you check the connect test it says that the connection test fail
  • Karin Malchus
    Karin Malchus Jun 28, 2016
    call a television repairman
2 Related Answers
Anonymous
SOURCE: how to connect sound system to Hisense LCD tv
I phoned the help line at Hisense, they stepped through the set-up - its all good now
Posted on Dec 31, 2009
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I have a hisense 50"
Hello dollfinn,
I'm going to need you to be a little more specific in your request. It is not possible to supply a manual without knowing the model number of the TV and I cannot tell you how or where to make connections without knowing what you are trying to connect.
Please could you provide as much detail as possible about your problem so that your question can be answered quickly and correctly. Please reply to me by clicking on "Add a Comment" below your question. The following details are essential:
1. Model number of TV
2. Brand and model numbers of devices you want to connect
3. Which cables you available for connecting the devices
Thanks,
BElectric
Posted on Feb 27, 2011
My smart tv - UN46ES7100F - won't find any wireless network. The Mac has fail. And the Service menu only shows SVC option
There are a few things that you can try in order to troubleshoot the issue with your UN46ES7100F TV not finding your wireless network.1. Verify if your wireless network is functional. To do this, try connecting another device to the wireless network and see if that can detect the network.2. Unplug your router and plug it back in after 30 seconds. This will often reset the connection and allow the TV to pick it up again.3. Check to make sure that your router is setup to broadcast the wireless signal. Some routers are setup to only allow certain devices to connect to the network by using MAC address filtering.4. Check if your TV is in Airplane Mode. To do this, press the Home button and go to Settings > General > Network > Set up Wireless Network and see if the Airplane Mode box is checked. If it is, then uncheck it and try connecting to the network again.5. Try resetting the Network Settings on your TV. To do this, press the Home button and go to Settings > General > Network > Reset Network Settings. Follow the on-screen instructions to reset the network settings on your TV.6. Consider connecting your TV to the network via an Ethernet cable. This will usually solve any connection issues since it won't rely on wireless signal.
I have a hisense tv 32” how do I connect to wireless wifi
Hisense Smart TV how to connect to WIFI
To connect to Wi-Fi, you need to have the WLAN switched on.
  1. In Settings select Wireless & Networks.
  2. Make sure the WLAN option is ticked.
  3. Select WLAN settings,
  4. Select the Wi-Fi signal within range and if it's secured you will need the password for it.
  5. Select connect.
Hisense Frequently Asked Questions Get Your Answers
1helpful
What operating system does this smart tv use, android, Google or something else, I can't find it anywhere in the manual
Bill, The 50H7GB's smart features are based on the Opera OS. Hisense uses an Opera-based platform for its connected features the same system/browser you'll find on Nintendo's DS and Wii video game systems.Check the attached links,instruction and guides, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Hisense H7GB2 4K Ultra HD Smart TV Review 50H7GB2 55H7B2 65H7B2
Hisense 50H7GB
Hisense The H7 4K Ultra HD TV
Can i connect a pc to a wii to view pc screens a my tv
Instructions things you'll need:
  • Wireless router
    • 1 Determine if your Internet connection is compatible with the Wii's online console features. If you are using a dial-up connection you will not be able to connect to the Internet through the Wii console. The best connectivity is with a cable, DSL or fiber-optic connection.
    • 2 Start up your Wii. Go to the main menu. Click on the Wii icon button on the bottom left side of the screen.
    • 3 Select the "Wii Settings" button with a wrench icon. Go to the "Wii System Settings" menu.
    • 4 Click on the arrow on the right side of the screen to scroll to page two of the settings. Click on the "Internet" tab.
    • 5 Select "Connection Settings" from the menu that appears. Your screen should show three connection slots all saying "none" next to them. Select "Connection 1."
    • 6 Choose "Wireless Connection" from the pop-up screen. A new screen will appear that reads "Search for an Access Point," "Nintendo Wi-Fi USB Connector," and "Manual Setup." The easiest way to set up the Wii online is to select "Search for an Access Point."
    • 7 Wait a moment for your Wii to find an access point. When the words "Choose the access point you want to connect to" appear on your screen, click "OK."
    • 8 Pick your access point. Choose the point that is listed with a green signal strength icon.
    • 9 Save the settings by clicking "OK." Your Wii console will perform a test. A window will pop up asking you to perform a Wii system update.
    • 10 Complete the system update. Read and agree to the "User Agreements." You should be able to view movies, TV shows, websites, news and games from your PC on your TV.
1helpful
We recently switched from Direct TV to Dish Network and now I can't get my Wi to show up on the tv screen.
Have you checked the cable that goes from the Wii to the TV, to see if it is plugged in? Have you checked if you are changing the input option on the TV, to view the one where the Wii is connected at?
1helpful
My wii keeps showing 51030 what does that mean and how to fix it to watch movies
error 51030
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
means that your wii is having trouble connecting to your wireless network.
please make sure that you wireless network signal is in range of the wii
setup your wii with wifi by going to the wii button on the home screen
wii settings> then page 2 select the internet.
go to wireless connection and connection 1 to setup your wifi.
search for access points and input the wireless security password to connect to the wireless network.
if this worked and you still get the error code please power cycle the wii and also check your wireless connection settings and any interference from other wireless networks. you may need to change the channel for the wireless network to 1 or 11.
1helpful
2answers
Wii remote
Is your sensor bar connected to the Wii? Check the sensor bar cable for cuts or severe bends (like a V shape) as they might cause the detection problems with the Wii-mote. A cheap fix is to put lit candles in front of your TV and see if the Wii-mote picks it up then.
2helpful
My itouch won't connect with my wireless network in my home. I have a Netgear router. My ITouch has been working (connecting) for over 6 monts without any problems. Nothing has been changed. All other...
I would turn your itouch on and tap the top bar where the battery and signal show.
a screen will pop down and show your wireless connection. tap it ans check your settings.
make sure you renew lease on your wireless and use the wep code which is on the label of your wireless router.
you should have signal now
good luck
Wii and PC signals no longer reach TV
try to check the drivers and if necessary reinstall it and look.try to chech the settings and also the connection cables also.thank you
Top Hisense Televison & Video Experts
Paul
Marvin
Marvin
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
