Electrolux EWFLS70JRR Energy Star Front Load Perfect Steam Washer with Logo
Question about Electrolux EWFLS70JRR Energy Star Front Load Perfect Steam Washer with
Electrolux screaching noise on spin cycle
When it's at the spin cycle there is a loud screeching noise
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Posted on Aug 26, 2014
AC Clutch noise and vibration
An A/C clutch will not make this concern happen, more likely the A/C compressor is begining to go out. The belt on the A/C clutch Assy. free wheels (spins feree on the pulley) when clutch is not engaged. If concern is not present with A/C off this means the bearings in the puley assy. ok. Once the A/C clutch is engaged it locks the compressor against the spinning pulley and turn the compressor chaft and spins the A/C compressor internal shaft. If you hear a loud "screach" when you turn on the A/C it means the belt slipped for a second, if it continiues to screach it means either the belt is loose or that the compressor is internaly locking up. I wouild start by checking the belt tension (if not equipted with and auto tensioner). You can also remove the belt and turn on the A/C and attempt to turn the clutch/pulley by hand, it should turn with a little effect but should not bind or lock at times if that happens compressor is bad.
1helpful
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Washer makes a loud, pulsing, screeching noise with no spinning
Sounds like a transmission problem. Not worth the repair judging from age.
Loud screeching noise when the wash and spin cycle ends
You either have something caught between the tub and basket or a bearing bad.
Eric
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
9helpful
3answers
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
