Question about DeLonghi EC155 Espresso Machine
Why hot water comes out of the machine but coffee doesn't drip down to cup
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: coffee machine leaking hot water also all lights come on front
Buy another one there like 10 bucks...
Posted on Jan 17, 2009
Anonymous
  • 18 Answers
SOURCE: i just got a eam
There is a blockage in the steam/ hot water circuit. By trying repeatedly to use these functions the steam boiler has now overheated and blown a thermal fuse ( thats why the alarm is displayed and now the infuser is in the wrong position for removal). If this machine is under warranty you should return it as soon as possible. If no warranty and you are a handy person (genuinely) then post again and i can help you fix it. No Good luck Rick.
Posted on Dec 12, 2010
Anonymous
SOURCE: The coffee grinds, and tamps, however no water
I had this same problem and fixed it according to a solution posted here by joebauer and it worked perfectly. He explains it better, but basically there is a brass part in the back of the machine (behind the U-shaped heating element) that gets stuck in the open position so that no water can get through. You have to remove it and give it a good whack on a hard surface. You know if it is unstuck by trying to blow air through the tube and it is not able to pass through. Make sure you unplug your machine before taking it apart.
Posted on Dec 15, 2010
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: new machine but no water
we repaire 07779933829 uk
Posted on Jan 25, 2011
Anonymous
SOURCE: I have the EAM3200 coffee maker and it seems to be
I have the same issue. I have tried replacing the O-rings in the water heating element and the steamer, and it still does this. For a temporary fix, try running the steamer for about 30 seconds, or until it is running "full steam", and immediately make your coffee. This has worked for my machine for the last 4 months. It is used about 5-10 times a day at my work, and this still is working. I believe the issues is it is losing pressure somewhere, and the water cannot travel through the infuser. I have taken apart my machine more than 10 times, and I still cannot find out where the pressure loss is. I know this is a temporary fix, but it will work until something more permanent can be done. Hope this helps!
Posted on May 27, 2011
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Won't pump when you put the cup in just a drip tryed diffrent cups but just a drip comes out when there is no cup the water comes out and it is hot
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
1helpful
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
10helpful
3answers
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
1helpful
No coffee
I had a similar problem with my XP 7240 with the coffee not coming out, but dripping through the machine and out the back. I found that overtime, there was a buildup of coffee in the "pod" area or percolation chamber and this was not properly removed. As a result, with additional cups being made, there was so much coffee compacted that it couldn't drip through.
I managed to clean it out by breaking up the compacted grains and it all worked fine. I also find that after each cup made, there is always some coffee grains left on the coffee cleaning tray above the grounds collector. I figured that this was the culprit as these grains would drop into the percolation chamber - adding this to the normal amount of coffee grains. It was never effectively cleaned out.
Now, I remove that tray after each cup, empty the grains and it seems OK. It's a pain, but I haven't had the problem for 2 months now.
Every now and then, I also get the vacuum cleaner and try to **** anything that might be oin there out.
Very slow water output
Open door of machine & take Brew head out. You will see a cylinder shaped part which is black with an orange washer half-way down it. Look underneath this cylinder and you will see a steel disk,(which may look black) this is the filtre. Now look above the cylinder and you will see a turn knob, turn anti-clockwise untill the disk comes free. Hold the disk up to the light and you will see the minute perferations which are all clogged with coffee grounds, give this a thorough washing under running hot water ,( use the brush provided with your machine to push the grounds through. You will also need to blow through these holes very hard and often untill you can see that they are cleared. This should be done after about every 15 cups made. I got this info. from the Gaggia engineer and it works!! Good luck.
1helpful
The krups coffee machine is letting out hot water but not coffee ?
If you find water in the spend grounds drawer or with the cup grid out you see water being dispensed into the drip tray your brew unit needs repair or replacement. If none of that is happening the tube that brings hot water to the brew unit is clogged.
1helpful
2answers
Water gets hot but doesnt pull water to grounds
It sounds like the tank isn't full. Unplug the machine and make sure there is a pot underneath to catch water. Pour clean water into the tank until it starts flowing out. Plug the machine in and let it heat up. Then try brewing coffee.
The way your machine works is that there is a holding tank for the water and it isn't actually brewing with the water you just poured in, it is using the holding tank water. If the holding tank gets low, and you pour water in all it does is fill the tank but nothing will come out.
Hope this helps.
DeLonghi EC155 Espresso Machine Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
