Question about FUJIFILM Cameras
Fuji troubleshooting when charging the battery the charging indicator is not displayed what should I do?
tomalex
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
Sometimes the chargers go bad. If it's under warranty, contact the manufacturer for a replacement. If not, you can get inexpensive chargers (sometimes with replacement batteries) from companies like Wasabi online.
Posted on Oct 07, 2014
Charge indicator
Perhaps you want to charge via a USB connector on your PC. Could be the PC connections are not correct for delivering 5V on that connector.
The manual also says:
Connect the camera directly to the computer; do not use a USB hub or keyboard.
Please try to charge via the external charger that came with the camera. If that fails too, please try to replace the USB cable.
Nov 09, 2013 | Fujifilm FinePix T400 Digital Camera Black
I have a fuji xp60. Just charged the battery. Insert into camera. Screen indicates date is not set. Controls will not allow me to set the date. The last time I had the camera out (May 2013) the screen...
I had a Fuji camera which did similar. It turned out to be a defective component inside the camera. Fuji do a repair service where you contact them for an estimate before repair. If the camera is old, it may not be worth the cost and cheaper to buy a later model. Sorry
Jan 20, 2018 | Fuji Rod Repair Kit
When i charge my camera i get a red light come on but other than that absolutely nothing. Is this a problem with the battery?
If you can turn on the camera while charging you can see the charging indicator on the LCD monitor which will indicate the level of charge the battery is currently at.
Jul 16, 2010 | Fuji FinePix Z1 Digital Camera
Could you please tell me where too look for how much battery live i have left. I have checked menu but can't find where it is.
The battery life indicator is only visible for a few seconds when the camera is first turned on. I believe it is in the top-left-hand corner of the display. It should be a horizontal picture of a battery, which is a solid-white when fully charged, and clear (outlined only) when the battery is getting low. If you don't have any indicators on the screen, press the "display" button to activate the icons.
Sep 27, 2009 | Fuji FinePix A900 Digital Camera
Low battery
As you have noticed, the battey is not charging completely which indicates a faulty battery. Too bad you didn't get it replaced when under warranty as they would have replaced it for you for free. ANyways you can get a replacement from here for about $14
http://www.wholesalebatteries.us/battery.cfm/hurl/Digital-Camera/FUJIFILM/FinePix-E550/PRO415-25.htm
Apr 21, 2009 | Fuji FinePix E550 Digital Camera
The Camera Fuji FinePix S2 Pro1 is not starting up
Generally, in indicator on the back display shows empty battery; sometimes after a short a message Err on a display
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji finepix v10 digital camera No.63A01601
Check Fuji Customer support re this. It may be a custom device that looks like a battery.
Aug 01, 2007 | Fuji FinePix V10 Digital Camera
Battery Problem
Hi, thsi indicate the internal short in circuit which draining excess current and battery get discharged. You nee dto chek internal circuit from technical expert. some component must be short . let em knwo when it solved. thanks Sangita
Jul 08, 2007 | Fuji FinePix A360 Digital Camera
Cameras Logo
94 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
