Question about Invacare Pronto M51 Power Wheelchair
Invacare pronto m51 manual
Where can I find a invacare m51 electronics manual
Posted by Joe Sherwood on
Derick Davis
    New Friend:
    Problem Solver:
  • 6 Answers
Posted on Aug 27, 2014
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: oil / gel leak
If it is coming from your motors, it could be very bad. i.e. motor replacement. Sometimes on the side of those motors there is a black plastic cap about the size of a quarter or half dollar, those fall out sometimes and allow gearbox grease to come out. This should`nt be confused with your motor brush caps which are about the size of a pea and have a small **** in them for a screwdriver.DO NOT TAKE THESE OUT.  If the large cap has come out just stick it back in. If you can`t find it you`ll ned to call a dealer to get the part replaced.    If you can still find no prob,your probably going to have to go to a dealer.
Posted on Mar 26, 2009
Anonymous
  • 17 Answers
SOURCE: speed control knob has come off
you need Invacare part # 1040225, cost about $6.00. Call these people 866-722-4581
Posted on Sep 22, 2009
Testimonial: "I looked on the internet for this part for HOURS without success. The "FixYa" expert found the model number needed and the phone # to order. Thanks!! "
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: i have invacare pronto m51 with surestep the spjis
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Posted on Nov 20, 2010
gnshome
  • 31 Answers
SOURCE: I have an invacare Pronto M51 Surestep power chair
If you have had swing away footrests on this chair you can replace them with model PHW93 and must ask to get them in red when you order them from a wheelchair store. If you dont know where a store is that sells Invacare products, call Invacare customer service at 800-333-6900.
Posted on Apr 07, 2011
badfish6686
Chris Weiser
  • 563 Answers
SOURCE: Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Posted on Apr 21, 2013
Testimonial: "Took the batteries back to Batteries Plus and had them tests. Load test was good but the capacity test showed batteries should be replaced. Replaced batteries but chair drives slower then it did with the bad batteries....barely moves when on low setting. "
Invacare Pronto M51 lights on controller blink 2 green 1 red
It means the battery voltage has dropped below the operating range of the chair electronics. Either need new batteries or maybe a charger and new batteries. There is always a chance of loose battery harness connections.
Jan 12, 2018 | Invacare Health & Beauty
How do I troubleshoot m51 pronto scooter. When I plug it in there is no lite and of course it does not run
  1. Pronto M51 Troubleshooting‎
    Adfixya.com/Pronto+M51+Troubleshooting‎1000's Solutions
  2. Troubleshooting Tips
  3. Free Diagrams
  4. Free User Guides
Service Indicator Light Diagnostics - Invacare Pronto M51 ...
www.manualslib.com > ... > Pronto M51 > Maintenance manual
Invacare Pronto M51 Base Manual Online: Service Indicator Light Diagnostics. ... Invacare power wheelchair owner's operator and maintenance manual.
Dec 25, 2015 | Health & Beauty
Reset button on pronto m51
There is no reset button on a M51 chair. Invacare puts fuses in the battery harnesses. The manual may say there is a reset but trust me there is not.
May 20, 2014 | Invacare Pronto M51 Power Wheelchair
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
http://www.invacare.com/doc_files/1125085J.pdf
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
May 06, 2014 | Jet 3 Ultra Power Chair
How do I find an electronics manual for the codes for the electronic on my daugters m51 wheelchair.
The complete service manual and diagnostic codes for this chair can be found at the following link:
http://www.invacare.com/doc_files/1125075.pdf
Hope this helps.
Jan 29, 2011 | Invacare Pronto M51 Power Wheelchair
Need operating manual
goto invacare.com when the home page comes up on the left side of the page you will see product catalog under that select Wheelchairs and top end. Next screen select Power Wheelchairs. Next screen select Pronto Series. Next screen select non-powered seating. Next screen select Pronto M51 with Sure Step. That is the last screen on the left side you will see owners manual select that and you can print it out with Adobe. Good Luck Hope this helps
Oct 11, 2010 | Invacare Pronto M51 Power Wheelchair
Manual for Pronto M51 wheelchair
Hi. We can supply, but try your local Invacare dealer. If you have luck, send us an email,
[email protected]
May 18, 2010 | Invacare Supply Group Invacare Pronto M51...
Where is the reset button on a invacare m51
The controller puts out fault codes though the LEDs. Count them and then look in the operators manual for likely causes. In my experience it is the electronic brakes that fail on these units and they are costly.
Oct 04, 2009 | Invacare Pronto M51 Power Wheelchair
Circuit Breaker on Pronto m51
http://www.invacare.com/doc_files/1125085.pdf
Here's the manual. Locate battery cables follow them to the motor and Joystick. you'll see the reset button
Aug 08, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
787 people viewed this question
Top Invacare Health & Beauty Experts
Rob Hill
Rob Hill
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
