When i connect my hdmi lead to my tv and laptop the screen on my laptop goes black, if i change the channel it goes back to normal? i know my tv is ok as my sky box is connected via a hdmi lead so why could this be happening? Im not very good with things like this so help would need to be very basic. Thanks in advance.
After connecting the cable press the Windows key and the P key at the same time. The projector options will appear. Change from projector only to the desired configuration.
Testimonial: "I'm not sure which setting to put it on?"
i dont know what config it needs though:-/
i have been on that but it didnt work?
a screen resolution icon came up saying its the wrong resolution but when eva i change it my screen goes black?
What version ofWindows? If the Windows key + P didn't work go to control panel and check the display settings.
If you want I can remote into your computer.
Email me at [email protected] if you're okay with remote assistance.
Ok will do
When you laptop goes black you need to have your computer in a remote view mode. That is normally done with "function 4". You have to hit the FN key and the 4 key together to get into the option. On different computers it is a different function key but that is the majority. When the screen comes up you should be able to select, view remote monitor, view local monitor or view both remotely and locally (local being your computer.
Testimonial: "Although I'm still having difficulty I'm very grateful of the help."
